Solving a Long Titration Problem: Net Ionic Equations & Mole Calculations
  • Thread starter Thread starter kuahji
    Titration
The discussion revolves around a complex double titration problem involving HCl and HBr, focusing on net ionic equations and mole calculations. Participants explore the relationships between the acids and their products, as well as the implications of the mass of precipitates formed during the reactions.
  • One participant outlines the steps taken to solve the titration problem, including writing net ionic equations for the reactions involved.
  • Another participant emphasizes that there is no indication of equal moles of HCl and HBr, suggesting the formulation of two equations with two unknowns to represent the moles of each acid.
  • Participants discuss the conversion of mass to moles in the context of the precipitate formed from AgNO3, noting the need to express grams in terms of moles using molar mass.
  • There is confusion regarding the manipulation of units between grams and molar mass, with participants clarifying that both sides of the equations must remain in consistent units.
  • One participant expresses difficulty in solving the equations due to the presence of unknowns in the denominator and the potential for negative values.
  • Corrections are made regarding the formulation of equations, with participants refining their approach to ensure proper unit consistency and algebraic manipulation.
Participants generally agree on the need to set up equations with two unknowns but express differing views on the approach to converting mass to moles and the implications of the unknowns in the equations. The discussion remains unresolved regarding the final calculations and the interpretation of the results.
Limitations include the lack of information about the initial mole ratio of HCl and HBr, which affects the ability to definitively solve for the quantities of each acid based on the mass of the precipitate. Additionally, the complexity of the algebra involved introduces potential for confusion in unit conversions.
kuahji
This was a pretty long double titration problem, I solved it all except for the last part & could use a bit of help because I'm stuck.
Part 1 A 100.00 ml solution containing aqueous HCl & HBr was titrated with .1200 M NaOH. The volume of base required to neutralize the acid was 47.14 mL. a) Write the net ionic equation for both reactions that occur during the titration.
Answer: 2H+ (aq) + 2(OH)- (aq) -> 2H2O (l)
Part 2 Determine the total number of moles of acid (HBr + HCl) in the original solution.
Answer: .002828 mol HBr & .002828 mol HCl
Part 3 Aqueous AgNO3 was then added to the solution (after the titration). Write the net ionic equation for both reactions that occur.
Answer: Br- (aq) + Cl- (aq) + 2Ag+ (aq) -> AgBr (s) + AgCl (s)
Part 4 The total mass of solid produced from the above reactions was .9975 g. Did the original solution contain more HCl or more HBr (in grams)?
This is the part I'm stuck on. At first I tried to take the mass percents of both of the solid products, into the total mass of the solid produced. But when I talked to my professor, she stated there wasn't necessarily equal moles of HCl & HBr in the beginning. Any ideas?
algebra, 2 equations, 2 unknowns
your professor is right that there is nothing in the problem that says there are equal numbers of moles of HCl and HBr
so the most you can do is say x mol HCl + y mol HBr = .0056568 moles
1. x mol Cl- + y mol Br- = .0056568 mol
that is your first equation with 2 unknowns
the second comes from the ppt with AgNO3
the two products AgBr and AgCl TOGETHER give a combined mass of .9975g
so g AgBr + g AgCl = .9975 g
but this doesn't have the same x and y as the first equation, so change g into something that has mol
MM = g/mol so instead of g make it
MM AgBr * y mol AgBr (write out the net ionic equation for AgBr)
or this is the same as g AgBr = MM AgBR * y mol Br-
do the same for AgCl, you get g AgCl = MM AgCl * x mol Cl-
put this back into the grams equation in green and this becomes equation #2
then its an algebra problem... good luck
I probably did too much for you...
Ok, so this makes sense, regarding setting up two equations with two unknowns. But if I convert the left side of equation 2 into moles, I still have it equal to grams. I thought about converting the right side into moles, but it doesn't seem like that can actually be done (for example, canceling out the grams with the molecular weight of AgBr + AgCl), & when I tried it, I came up with negative numbers for x & y. Thanks for getting me this far at least.
you can't cancel out grams and MM of AgCl, AgBr, they don't have the same units
MM = g/mol
both sides of equation 2 are in grams
MM AgCl =
mol Cl-
= g/mol
mol
gives grams on both sides.
put the numbers in for MM AgCl and AgBr, to make it look better
it is not a nice problem because you have your unknowns in the denominator.hope you're good at algebra
I broke the second equation down like this
g AgCl + g AgBr = .9975g
1 g AgCl x (1 mol AgCl/143.25g AgCl) x (1 mol Cl-/1 mol Ag Cl) = .0069759 mol Cl-
doing the same for AgBr I got .0053248 mol Br-
Of course doing this, would leave the other side of the equation in grams.
Ok, so that doesn't work so well. From what I'm gathering your saying
187.7 g AgBR/1 mol x 1 mol Br- = g AgBr which I guess would give me 187.7 MM AgBr/1 mol Br-
For AgCl its 143.15 MM AgCL/1 mol Cl-
So if I plug those numbers into the equation its 187.7 MM AgBr/1 mol Br- + 143.15 MM AgCl/1 mol Cl- = .9975
This is where I'm a bit confused. Having the unknown in the denominator wouldn't be a problem, because you could just invert the whole equation, then use whatever method you like to solve the variables in the two equations (Crammer's Rule is what I usually use for small systems like this one). But does the MM AgBr & MM AgCl every cancel out, or is it just not needed?
MM = g/mol
MM AgCl =
mol Cl-
= g/mol
mol
SORRY! you're right its not in the denominator
I was muddling my MM = g/mol equn
this should be right
equn 2 is 187.77 * y mol Br- + 143.33 * x mol Cl- = .9975 grams
equn 1 is x + y = .0056568
let y = .0056568 -x
then 187.77 (.0056568 - x) + 143.3 * x = .9975 g
DO be careful with your signs, it looks like x might be neg but you need to bring numbers to the right hand side and keep x on the left (you get neg on both sides which cancel out to give a pos value for x)
SORRY again about my last post , this one does works out
12K
