[SOLVED] Finding Tension in Scaffolding
by Dante5454
Tags: scaffolding, solved, tension
Dante5454
Dante5454 is offline
#1
Nov12-07, 12:12 PM
P: 3
A 656N window washer is standing on a scaffold supported by a vertical rope at each end. The scaffold weighs 171N and is 4.58m long. Assume the window washer stands 1.33m from the left end. What is the tension in both ropes. (Answer in N)
2. Relevant equations
Static Equilibrium States [tex]\Sigma[/tex]Torques=0 also [tex]\Sigma[/tex]Forces=0
3. The attempt at a solution
I first solved for the center of gravity, using the left end as a datum using the equation (sum of moments)/(sum of masses) = center of gravity. Then, using my new point as the lever arm for the board's weight, I solved for torque in the downward direction and thought that tension should have to be equal. I am doing this as a part of an online course, and submitted my answer, which was incorrect. I could really use help, thanks.
Phys.Org News Partner Science news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Microbes provide insights into evolution of human language
mgb_phys
mgb_phys is offline
#2
Nov12-07, 12:43 PM
Sci Advisor
HW Helper
P: 8,961
First get the force due to the scaffold itself. This is the obvious case with nobody on it - divide that equally between the two ropes.
Now work out the total force due to the person - obviously this weight must be added to the force on the ropes, but divided between them in some ratio.
Consider what the force on each rope would be if the person was standing 1, directly under the other rope, 2, in the centre of the platform ?
You don't have to actaully work out the moments - the ratio should be obvious.
Dante5454
#3
Nov12-07, 12:49 PM
P: 3
Perfect! Thanks so much, mgb! I just took half of the force of the scaffold, 85.5 and added it to (1.33/4.58) for the left side, and added it to (3.25/4.58) for the right side. It worked perfectly! Thanks again!
Register to reply
Related Discussions
[SOLVED] Finding mass per unit length for stretched strng given tension? Introductory Physics Homework 1
Finding the Tension Introductory Physics Homework 14
Finding Tension in a Rope Introductory Physics Homework 17
Finding tension Precalculus Mathematics Homework 1
Finding tension Introductory Physics Homework 7
