Rate of spring compession from block on incline
The problem involves a block sliding down an incline and colliding with another block that compresses a spring. The parameters include the masses of the blocks, the spring constant, the angle of the incline, and the coefficient of friction. The goal is to determine the amount of compression of the spring.
  • Participants discuss the initial conditions of block 1, including its rest state and distance to block 2. There are attempts to calculate forces acting on block 1 and how to incorporate the coefficient of friction. Questions arise about the role of block 2 and how to account for its mass in the calculations.
Some participants have provided calculations for the forces acting on block 1 and suggested using a free body diagram to clarify the situation. Others have raised questions about the nature of the collision between the blocks and how energy is transferred, indicating a lack of consensus on the approach to take.
There is uncertainty regarding the initial velocity of block 1 and the type of collision (elastic or inelastic) that occurs between the blocks. Additionally, the effect of the coefficient of friction on the calculations is under discussion.
december7
Block 1 slides down an slope to hit block 2, which compresses a spring. How much compression does the spring experience? Mass - block 1=10 kg, block 2 = 1 kg, spring constant = 500 N, angle = 35, acceleration due to gravity=9.8
m/s, ukf = 0.1
ws = (1/2)*kx^2 = w(net force) d cos 0
ws= (1/2)*500*x^2 = (9.8*10) 3 (cos 35)
without the coefficient of static, and the mass of block 2
ws= (1/2)*500*.9815^2 = (9.8*10)3(cos35)
1=240.83
not sure how to work in the coefficient of static on block 1, and uncertain how to account for the effect of block 2 (1 kg)
Not enough information. What are the initial conditions for Block 1? How long before it hits Block 2?
Block 1 is at rest, distance is 3M to Block 2.
I am unsure if the the '(9.8*10) 3 (cos 35)'
can be used, as well as how to integrate the
coefficient of 0.1 for ufk. Finally, how to deal
with this force when it meets block 2 (1 kg)
which separates Block 1 from the spring.
Thanks.
Best way to get the Block 1 situation clear is to draw a free body diagram. That will give you the force accelerating it (the component of its weight acting down the slope less frictional force). That will lead to knowing how fast it is traveling when it hits Block 2 ...
I have calculated 10*9.8*sin35 = 56.21 - 10*9.8*cos35*0.1 = 48.18 * 3M
= 144.54N. This is the only way I have been able to find to do this. I'm not sure how to deal with the 1 kg block which sits at the end of the spring. The calculated mass will be exerted against the 1 kg block, which in turn will compress the spring X amount. It is this amount of compression that is sought. Based on PES = (1/2)KX^2. (with spring K=500) Forgetting about the 1 kg block for a moment, I thought I could possibly take 144.50/250 =0.578 = square root of 0.578 = 0.76M spring compression. Even if this is close to correct, it disregards the 1 kg block. Any input appreciated. Thanks.
You also have to know if the collision between the blocks is elastic or not. That way, you’ll know how much energy is transferred to block 2.
The velo of block 1 just before hitting block 2 should be clear enough, since all the data are given.
  • · Replies 27 ·
11K
