Why Is the Magnetic Vector Potential Azimuthal Inside an Infinite Solenoid?
The magnetic vector potential inside an infinite solenoid is azimuthal due to the symmetry of the magnetic field generated by the solenoid. The formula A(𝑟) = ∫𝑣 (𝑗(𝑟′)/𝑟) dτ is not applicable because of the infinite extent of the current. Instead, the magnetic field B can be determined using the integral form of Ampere's Law, and the vector potential A can be deduced by recognizing that B = Curl(A). This approach simplifies the calculation of A in the context of an infinite solenoid.
  • Understanding of magnetic vector potential and its significance in electromagnetism
  • Familiarity with Ampere's Law and its integral form
  • Knowledge of vector calculus, specifically the Curl operator
  • Concept of symmetry in magnetic fields, particularly in solenoids
  • Study the derivation of the magnetic field inside an infinite solenoid using Ampere's Law
  • Explore the mathematical properties of the Curl operator in vector calculus
  • Investigate the physical implications of magnetic vector potential in different geometries
  • Learn about the applications of magnetic vector potential in advanced electromagnetism
Physicists, electrical engineers, and students studying electromagnetism who seek to deepen their understanding of magnetic fields and vector potentials in theoretical and practical applications.
pardesi
Why is the magnetic vector potential of a point inside a infinite soleniod azimuthal assuming the axis of solenoid is the z axis.
Problem is the formulae [itex]A(\vec r)=\int_{v} \frac {\vec J(\vec r^{'})}{r} d\tau[/itex] doesn't hold any more due to the infinite extent of the current
When you say "why is" I assume you mean "what is", and A is simple to find in this case because you can find B using the integral form of ampere's law and then guess A by looking at B = Curl(A).
  • · Replies 21 ·
