Thread Closed
Verilog arithmetic shift implementation.
Share Thread Thread Tools
Nov15-07, 07:24 PM   #1
Here's my verilog code first of all
module arithmetic_shift(input_num, op, shift_num, result);
input [7:0] input_num;
input [2:0] shift_num;
input op;
output reg [7:0] result;
always @ (*)
case(op)
0 : result = input_num <<< shift_num;
1 : result = input_num >>> shift_num;
default : $display("Error in Arithmetic Shift Module");
endcase
endmodule
module arithmetic_test;
reg [7:0] input_num;
reg op;
reg [2:0] shift_num;
wire [7:0] result;
arithmetic_shift UUT(input_num, op, shift_num, result);
initial
begin
input_num = 0;
op = 0;
shift_num = 1;
#50 input_num = 8'b10101010;
#100 input_num = 8'b11110000;
#150 op = 1;
input_num = 8'b11010001;
shift_num = 3;
end
endmodule
I am using Xilinx to run my simulation.
When I run the syntax check on my code, there are no problems at all. However, when I actually try to run the simulation, I get an error
# Loading work.arithmetic_test
# Loading C:\Modeltech_xe_starter\win32xoem/../xilinx/verilog/xilinxcorelib_ver.arithmetic_shift
# Loading work.glbl
# ** Fatal: (vsim-3365) Testbench.v(12): Too many port connections. Expected 3, found 4.
# Time: 0 ps Iteration: 0 Instance: /arithmetic_test/UUT File: C:/Xilinx/verilog/src/XilinxCoreLib/XFFT1024_V1_1.v
# FATAL ERROR while loading design
# Error loading design
Stating that the instantiation being done on this particular line
Does not match the port connections with the actual module. Clearly, this cannot be true as there are 4 ports going in/out of the code.
So here's my question - did I write something wrong on the code to cause this trouble or is Xilinx smoking marijuana?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Thread Closed
Thread Tools
Similar Threads for: Verilog arithmetic shift implementation.
Thread Forum Replies
Help with Verilog Engineering Systems & Design 0
Does anybody know verilog? Electrical Engineering 1
verilog help Electrical Engineering 2
Verilog help Electrical Engineering 2
Doppler shift and red/blue shift General Astronomy 4
