Computation of an integral (Use of Resdiue theorem).
The discussion revolves around the computation of the integral \(\int_{0}^{\infty} \frac{\cos(x)}{\cosh(x)} \, dx\), with a focus on using the residue theorem and contour integration techniques. Participants explore the implications of singularities and the choice of contour for evaluation.
  • Exploratory, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the use of a rectangular contour and the implications of singularities within the chosen contour. There are suggestions to express the integrand in terms of complex exponentials and to consider the behavior of integrals as the contour radius approaches infinity. Some participants question the necessity of bounding terms and the behavior of imaginary components in the integrals.
The discussion is active with various approaches being explored, including the use of different contour shapes and the application of the residue theorem. Some participants offer guidance on how to parameterize the contour and evaluate integrals, while others express uncertainty about specific steps and the behavior of certain terms as limits are taken.
There are mentions of potential complications arising from singularities and the need to ensure that certain integrals vanish as the contour is adjusted. Participants are also navigating the constraints of the problem, including the requirement to evaluate integrals over specific paths in the complex plane.
MathematicalPhysicist
I need to compute the integral:
[tex]\int_{0}^{\infty}dx\frac{cos(x)}{cosh(x)}[/tex]
so obviously i need to use the residue theorem here and evaluate the contour integral of the complex function (cos(z)/cosh(z)) the singularity point here is [tex]z=i\pi/2[/tex]
the intervals i decided to do the are:
(0,0)->(R,0)->(R,pi)->(0,pi)->(0,0)
and then ofcourse we shall let R approach infinity.
so by the residue theorem we get that:
[tex]\int_c\frac{cos(z)}{cosh(z)}=2i\pi Res(cos(z)/cosh(z),z=i\pi/2)[/tex]
on the other hand, after some algebraic manipulations we get that:
z=x+iy [tex]cos(z)/cos(z)=(cos(x)cos(y)cosh(x)cosh(y)+sin(y)sin(x)sinh(y)sinh(x))/(cos^2(y)cosh^2(x)+sin^2(y)sinh^2(x))([/tex]
now to calculate the integral we have that:
the above integral with z equals (before letting R approach infinity):
[tex]\int_{0}^{R}\frac{cos(x)}{cosh(x)}dx+i\int_{0}^{\pi}\frac{(cos(R)cos(y)cosh(y)cosh(R)+sin(y)sinh(y)sin(R)sinh(R))}{cos^2ycosh^2R+sinh^2ysinh^2R}-\int_{R}^{0}\frac{cosh(\pi)cos(x)}{cosh(x)}dx+i\int_{\pi}^{0}cos(y)cosh(y)dy[/tex]
now i think that one of the above summed integrals is when R approaches zero approaches zero as well, to prove this would be quite long cause i think i need there l'ohpital rule, the second imaginary part shouldn't be too much of a hastle, by parts, i just want to see if this approach is the correct one, or is there a simpler appraoch that will make my life easier?
thanks in advance.
[tex] \int\limits_0^\infty {\frac{{\cos x}}{{\cosh x}}dx} = \frac{1}{2}\int\limits_{ - \infty }^\infty {\frac{{\cos x}}{{\cosh x}}dx = \frac{1}{2}\int\limits_{ - \infty }^\infty {\frac{{e^{ix} }}{{\cosh x}}} } dx[/tex]
Doing it this way, you can avoid having to bound the cosine term explicitly.
Edit: Your approach in using a rectangular contour is correct. You don't need to evaluate any integrals. The whole point of using such a contour is to enable you to end up with an integral of the same form as the original one you are trying to evaluate. You obtain such an integral by letting R approach infinity so that (in this case) two of the integrals vanish.
Doesn't the contour you chose include the singularity? Specifically, the segment:
[tex]0 + i \pi \rightarrow 0 + i0[/tex]
seems to include
[tex]0 + i \frac{\pi}{2}[/tex]
Since the function is even, you can do something like this:
[tex]\int_{0}^{R} \frac{\cos(x)}{\cosh(x)}dx=\frac{1}{2} \int_{-R}^{R} \frac{\cos(x)}{\cosh(x)} dx[/tex]
I'd be tempted to try a half-circle complex countour - no idea if it works out well.
A rectangular contour, as the thread starter has attempted to use, is the way to go. The method is to calculate the integral in two ways, one directly via the residue theorem and the other by parameterising the contour.
A semi circular contour will probably not work. This is because as the radius increases, more and more singularities will be enclosed which will be inconsistent with the calculation using the residue theorem.
Despondent said:
A rectangular contour, as the thread starter has attempted to use, is the way to go. The method is to calculate the integral in two ways, one directly via the residue theorem and the other by parametrising the contour.
Yeah. Sometimes circular contours lead to nice cancellation - not this time though.
those with the imaginary coeffiecients vanish correct?
but i don't see how does the second imaginary integral get vanish after letting R approach infinity, if it does get vanish it should have no relevance to R cause it doesn't depend on it.
I think you should go with my suggestion to write the integrand in terms of the complex exponential. You don't need any tricks here (eg. multiplying the numerator and the denominator by some function).
The contour C you should use has vertices -R, R, R + (pi)*i, -R + (pi)*i which you have indicated the use of in your original post.
The integral can be calculated using the residue theorem as you've done. The second way is to parameterise the contour. You can do this as follows.
The integral is [tex]\int\limits_0^\infty {\frac{{\cos x}}{{\cosh x}}} dx = \frac{1}{2}\int\limits_{ - \infty }^\infty {\frac{{e^{ix} }}{{\cosh x}}} dx[/tex].
So the integral you need to consider is:
[tex] J = \int\limits_C^{} {\frac{{e^{iz} }}{{\cosh z}}dz} [/tex]
[tex] = \int\limits_{ - R}^R {\frac{{e^{ix} }}{{\cosh x}}dx + \int\limits_0^\pi {\frac{{e^{i\left( {R + iy} \right)} }}{{\cosh \left( {R + iy} \right)}}} } idy + \int\limits_R^{ - R} {\frac{{e^{i\left( {x + i\pi } \right)} }}{{\cosh \left( {x + i\pi } \right)}}} + \int\limits_\pi ^0 {\frac{{e^{i\left( { - R + iy} \right)} }}{{\cosh \left( { - R + iy} \right)}}idy} [/tex]
The second and fourth integrals can be shown to vanish in the limit as R goes to infinity. Just use
[tex]\left| {\int\limits_C^{} {f\left( z \right)dz} } \right| \le \mathop {\max }\limits_{z \in C} \left| {f\left( z \right)} \right| \times length\left( C \right)[/tex].
You can now use some identities to combine the first and the third integral to get some multiple of the integral that you want to evaluate.
  • · Replies 18 ·
  • · Replies 19 ·
