Thread Closed
thermal conductivity
Share Thread Thread Tools
Nov17-07, 12:05 AM   #1
A mountain climber wears a goose down jacket 3.28 cm thick with total surface area 1.10 m2. The temperature at the surface of the clothing is -19.3°C and at the skin is 36.0°C. Determine the rate of heat flow by conduction through the jacket assuming it is dry and the thermal conductivity, k, is that of down.
Part 2:
Determine the rate of heat flow by conduction through the jacket assuming the jacket is wet, so k is that of water and the jacket has matted down to 0.462 cm thickness.
2. Relevant equations
thermal conductivity of goose down is .025 J/(mKs)
thermal conductivity of water is .561W/(mKs)
phi dot = KA (delta T/delta X)
K is goose down (.025 j/smk)
A is area
T is temperature
x is distance heat flows
Part 2
The rate of heat flow= (the rate of heat flow you found in
part 1) x (k water/ k goose down) x (thickness of goosedown/
thickness of wet jacket)
3. The attempt at a solution
.025*(.0328*1.10)*(36+19.3/.0328)
I get the rate is 1.52 W, yet it is the wrong answer. If I had that answer I could use it to get part 2 where I would do the following
rate=rate1*(.561/.025)*(.0328/.00462)
Please let me know what I am doing wrong! Thank you!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Nov17-07, 01:24 AM   #2
Recognitions:
Homework Helper Homework Help
Why is the distance between the two surfaces in the numerator? Delta_x should be in the bottom.
Thread Closed
Thread Tools
Similar Threads for: thermal conductivity
Thread Forum Replies
Thermal Conductivity General Physics 0
Thermal Conductivity Introductory Physics Homework 0
Thermal Conductivity Introductory Physics Homework 3
Thermal conductivity: are liquids better thermal conductors? Introductory Physics Homework 1
Thermal conductivity Introductory Physics Homework 5
