| Thread Closed |
[SOLVED] Linear Transformations (polynomials/matrices) |
Share Thread |
| Nov17-07, 03:13 PM | #1 |
Never mind, I can see it now, thanks
1. The problem statement, all variables and given/known data Let S be the linear transformation on P2 into P3 over R. S(p(x)) = xp(x) Let T be the linear transformation on P3 over R into R2x2 defined by T(a0 + a1x + a2x^2 + a3x^3) = [ a0 a1; a2 a3] Find a formula for TS(p(x)). 3. The attempt at a solution The first thing I do is find the S(A) where A is the standard basis of P2 and I place that into a transition matrix from the basis B (std. basis of P3). [S]B,A = [0,0,0;1,0,0;0,1,0;0,0,1] Then I do the similar steps for fining [T]C,B where C = E2x2 [T]C,B = I4 (identity matrix of a 4x4) Multiplying the matrix yields: [T]*[S] = [0,0,0;1,0,0;0,1,0;0,0,1] I am fairly positive that the math up to this point is accurate. (I get the correct range of T). My question is how do I specifically find the formula for TS(p(x)) using the last matrix that I found? I know it's a mapping of P2 into R2x2, but I don't quite see how they get [0, a0; a1, a2] as the matrix. I know it lines up with TS, but still |
| Thread Closed |
Similar discussions for: [SOLVED] Linear Transformations (polynomials/matrices)
| [SOLVED] Linear transformations | Calculus & Beyond Homework | 2 | ||
| [SOLVED] Linear algebra - transformations | Calculus & Beyond Homework | 2 | ||
| [SOLVED] Linear algebra - transformations | Calculus & Beyond Homework | 5 | ||
| [SOLVED] Combined linear transformations | Calculus & Beyond Homework | 1 | ||
| thinking about matrices/polynomials | Linear & Abstract Algebra | 2 | ||
