Chemical Reaction between water and chlorine
The discussion revolves around the chemical reaction between chlorine and water, specifically focusing on the products formed and the correct nomenclature of the acids involved. The scope includes homework-related inquiries and clarification of chemical formulas and names.
  • Homework-related, Conceptual clarification, Debate/contested
  • One participant proposes the reaction: Cl2(g) + H2O(l) <----> HCl(aq) + HClO(aq).
  • Another participant suggests that the correct term should be hypochlorous acid (HOCl) instead of chloric acid.
  • A participant questions whether hypochlorous acid and chloric acid are the same, indicating a potential misunderstanding of the terms.
  • It is clarified that hypochlorous acid is indeed the correct term, while chloric acid refers to a different compound with the formula HClO3.
  • Participants discuss the implications of oxidation states in determining the correct nomenclature for the acids.
Participants express differing views on the nomenclature of the acids involved, with no consensus reached on whether hypochlorous acid and chloric acid are interchangeable terms.
There are unresolved issues regarding the definitions and distinctions between hypochlorous acid and chloric acid, as well as the implications of oxidation states in their chemical formulas.
Suitengu
[SOLVED] Chemical Reaction between water and chlorine
Whats the reaction between chlorine and water
None
Is it the reversible reaction:
I think you were going for chloric acid which is actually HOCl otherwise it's correct
arent they the same thing just different methods of writing it. and that would be hypochloric acid not chloric acid right?
They are the exact samething but it's hypochlorous acid. It's just chloric acid is the more common name and it's formula is HOCl.
Edit: The reason it's not HClO is because that implies that the central atom is Cl which it is not..
Also to clarify hypochlorous acid is the same as Chloric (1) acid. But chloric acid is different because of the oxidation states which means it will be HClO3. Thank you for correcting me.
no problem and thank you too for correcting me.
