| Thread Closed |
How unlike real elevator (Rindler field) is field from planar mass? |
Share Thread | Thread Tools |
| Nov20-07, 05:00 AM | #1 |
For years I thought that, except for tidal field and the g = -(c^2)/Z
issue, the essentially "uniform" gravity field near a wide (approx. to "infinite") planar mass sheet would be just like that of the accelerating elevator of historic fame in GR. I thought I could use whatever happened, local neighborhood, in the Rindler field (RF) to predict what would happen in the field (PF) of the planar mass. Well, after discussions in a Cosmic Variance thread (http://cosmicvariance.com/2007/11/13...tum-mechanics/) with the apparently knowledgeable Greg Egan, that assumption is blown. In particular, I thought: what could be more assured, than in a uniform PF, everything would fall at the same rate no matter what its circumstance. Not just composition etc., but lateral motion as well. A horizontally traveling bullet hits the ground the same time as a dropped body, we expect from naive Equivalence Principle. That should apply to a light beam as well, the double deflection around a radial field being due to extra "space curvature" effect and not some inherent distinction. But, Greg says: No, the RF and PF metrics are not the same, and it matters for *local* experiments. The lab-frame acceleration of a body in rapid transverse motion in a PF is: g(moving) = g(1 + v^2/c^2). I thought, WTF?! He says: Greg Egan: "In the Rindler "elevator", transverse motion is just an extra degree of freedom that has no effect whatsoever in the Z direction. In the curved space-time near a planar mass, the geometry is sliced differently by world lines with different transverse velocities." That just seems weird to me, but if it is, it is. I still worry about one thing: energy conservation. He says the change in transverse velocity compensates so as to get correct impact energy during a fall. But I had a proposal, which may or may not have the apparent weight corrected appropriately: Neil Bates: "... Let's have constrained matter flowing rapidly in a circular path on the floor. Let's assume, from f = ma in the proper frame of the mass particles (there should be a consistent relation between what free acceleration is seen, with force in the constrained case), that the lab force is now increased to gamma(1+v^2)* m_0*g instead of the gamma* m_0*g that we expect from increased effective mass-energy. Now lets lower a shelf holding this ring, extracting work according to W = - f dot delta h. Then we slow down the ring current, leaving the same mass energy as before (but now same as rest mass.) Then we could raise the ring using only gamma* m_0*g delta h, giving us "free energy" of gamma * v^2 * m_0*g delta h. ..." Later, I conjectured: " ... is the correction for free fall equivalent to an effective "weight" of just gamma*m_0? If not, I don't see how an effective mass of (1 + v^2) could square with conservation during raising and lowering. Wow, losing the "elevator" as game for whatever I wanted to think about is really disappointing (and low to middle-brow science education doesn't [warn] about this much - I just didn't get into gravity at top level. ..." So, what's the scoop on this issue? Why don't we hear more about it (or am I not looking in all the right places ...)? What else can't I trust RF to PF equivalence on? Finally, do weak gravitational fields (i.e., their effects in every way, including the peculiar velocity-dependent acceleration) obey superposition, basically? (Like, an effect of magnitude 3 and one of magnitude 5 might add to 7.99 or 8.02 etc., but not way off like adding to two or 16 etc.) tx Greg's page about gravity etc: http://gregegan.customer.netspace.ne....html#CONTENTS Other references to this issue: http://www.mathpages.com/home/kmath530/kmath530.htm http://arxiv.org/pdf/gr-qc/0503092 http://arxiv.org/PS_cache/arxiv/pdf/...708.2906v1.pdf |
| Thread Closed |
| Thread Tools | |
Similar Threads for: How unlike real elevator (Rindler field) is field from planar mass?
| the Higgs field: so gravitational field by itself cannot confer mass? | High Energy, Nuclear, Particle Physics | 4 | ||
| Complex Scalar Field in Terms of Two Independent Real Fields | Quantum Physics | 4 | ||
| Is the usual non-abelian gauge field A real or complex? | Quantum Physics | 1 | ||
| Is Yong-Mills field real or complex? | Beyond the Standard Model | 0 | ||
| Rindler - Mass of Charged Capacitor | General Physics | 0 | ||
