Thread Closed
Choosing a solvent
Share Thread Thread Tools
Nov22-07, 10:43 AM   #1
Choosing a solvent
Here is the question I have, any help would be greatly appreciated.
Which of the following organic solvents could be used to extract a neutral organic compound from an aqueous solution?
ethyl acetate;
ethanol;
dichloromethane;
hexane;
acetic acid.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Nov22-07, 11:33 AM   #2
Quote by tom717 View Post
ethyl acetate;
ethanol;
dichloromethane;
hexane;
acetic acid.
If with "neutral" you mean "non polar" then you have to choose the less polar of the solvents, that is hexane.
Nov22-07, 12:17 PM   #3
Thanks. I guess that is what was meant by neutral, I can't be certain as I gave you the exact wording of the question so that's all there is to go on.
Nov22-07, 12:19 PM   #4
Recognitions:
Choosing a solvent
Dichloromethane is a good answer too since it settles to the bottom. You could extract the organic pieces without having to remove the water first.
Nov22-07, 03:29 PM   #5
I vote for dichloromethane too, polar enough to get good mixing with the water, organic enough to extract the organic compound, density is great for easy separation.
Nov22-07, 08:06 PM   #6
Recognitions:
Homework Helper Homework Help
Quick best guess is all of those except acetic acid. Better guess, maybe all except exclude acetic acid and exclude ethanol. Do you mean "neutral" in relation to acidic or alkaline; or do you really mean nonpolar?
Nov22-07, 09:04 PM   #7
Recognitions:
Quote by symbolipoint View Post
Acetic acid and ethanol would be terrible choices because they completely mix with water. It would either create one big phase, or it would have little separation. Ethyl acetate would probably work, but it's not the best choice because the density is somewhat close to water; it's about 0.9. Dichloromethane is very heavy at around 1.3, and hexane is very light at maybe 0.7
If you're allowed to pick more than 1, I would pick DCM, hexane, and ethyl acetate.
Nov22-07, 10:01 PM   #8
Recognitions:
Quote by ShawnD View Post
Good Points. I did not think very clearly when I made my comment. I had imagined a mixture straight from solid phase; not exactly what many people have available once they are ready to use a solvent for extraction. Not all extractions are performed directly upon a liquid solution.
Thread Closed
Thread Tools
Similar Threads for: Choosing a solvent
Thread Forum Replies
Solvent washing Chemistry 13
how can I solvent collagen? Biology 4
Phenol-formaldehyde synthesis and solvent Chemistry 2
Supercritic CO2 as an extraction solvent Chemistry 1
