Register to reply
Equilibrium question.
by kjthesandman
Tags: equilibrium
Share this thread:
kjthesandman
#1
Nov23-07, 08:52 AM
P: 3
I was having trouble calculating the equilibrium of this object. I thought I had to solve it using the scalar cross product...but i'm not certain I am on the right track. Can some one help me? This is the question.
A carpenter's square has the shape of an L, where d1 = 19.0 cm, d2 = 6.00 cm, d3 = 6.00 cm, d4 = 11.0 cm. Locate its center of gravity. (Hint: Take (x, y) = (0, 0) at the intersection of d1 and d4)
Phys.Org News Partner Science news on Phys.org
'Smart material' chin strap harvests energy from chewing
King Richard III died painfully on battlefield
Capturing ancient Maya sites from both a rat's and a 'bat's eye view'
azatkgz
#2
Nov23-07, 09:36 AM
P: 196
Can you please draw this carpenter.I'll try to help you.
Like this?
kjthesandman
#3
Nov24-07, 06:24 PM
P: 3
Sort of, actually d3 is connected to d1, and d1 is the longer side of the carpenter square. The picture looks more like this...
PhanthomJay
#4
Nov24-07, 06:57 PM
Sci Advisor
HW Helper
PF Gold
PhanthomJay's Avatar
P: 6,049
Rather than using cross products, break up the shape into 2 rectangles, and sum moment areas about each axis separately , where the moment of an area is the area times the perpendicular distance from its centroid to the axis, and where
(A1)x1 + A2(x2) = (A1 + A2)(X_), etc., (which you are familiar with?).
kjthesandman
#5
Nov24-07, 08:23 PM
P: 3
Well I was using the equation ((m1)(x1)+(m2)(x2))/(m1+m2)= but i keep getting the wrong answer...using this method how do i find y1, y2, and x1, x2. I know it seems like a real fundamental question but I am still having trouble.
PhanthomJay
#6
Nov24-07, 09:40 PM
Sci Advisor
HW Helper
PF Gold
P: 6,049
Quote Quote by kjthesandman View Post
x1, x2, y1, and y2, are the perpendicular distances from the centroids of each area to the origin. For example, one of the rectangles is 19 by 6. For that particular rectangle, since its centroid is at its geometric center, then x1 is 3 and y1 is 9.5. Now find the centroid of the second rectangle, and the corresponding x2 and y2 distances. Be sure to use A1 and A2 for what you are calling m1 and m2.
azatkgz
#7
Nov24-07, 11:23 PM
P: 196
Centre of mass is between two centres of mass,so in the red line.Where the red lines coincide,there is the centre of mass of the carpenter.
Register to reply
Related Discussions
Equilibrium question Chemistry 3
Equilibrium Question Chemistry 4
Equilibrium Question Introductory Physics Homework 1
An Equilibrium Question Introductory Physics Homework 5
Equilibrium Question Introductory Physics Homework 7
