| Thread Closed |
Tricky Multiple integral word problem |
Share Thread | Thread Tools |
| Nov24-07, 02:52 PM | #1 |
So Ive been talking with some people about this problem, but I cant seem to find the answer, or even set it up!
"A region in space, when viewed from 3 different views, looks like a circle, looks like a square and looks like a triangle. Describe this object. And then use multiple integration to determine its volume" So if you think of any two shapes its pretty easy. Such as square and triangle = pyramid, circle and square = cylinder and so on. But I couldnt figure out a shape for when you add the third shape. And then Figuring out the integral would be even more difficult. What do you guys think about it? =D |
| Nov24-07, 03:34 PM | #2 |
you almost had it with the circle+square=cylinder, what if you were to have only a square from the "top/bottom" and the sides a triangle?
| Nov24-07, 03:43 PM | #3 |
Im still not getting it.. Pictures would help. >.<
So Square base and top. Sides triangle? Where would the circle go? |
| Nov24-07, 03:45 PM | #4 |
it's originally a cylinder, 2r=height, so from 2 sides you'd have a square. and now cut off some part in order to get a triangle from the other 2 sides. So it looks like a wedge with a circular base and square top/bottom.
| Nov24-07, 04:40 PM | #5 |
OH I think I get it now. So bascially, its 1/2 a cylinder right?
http://img77.imageshack.us/img77/8178/shapehi9.gif So side view is square, bottom is circle and other sides are triangles. Thanks!! But how would I find the volume of that shape?
| Nov24-07, 04:47 PM | #6 |
hm..depends how you place the axis's on it, but I think you'll need to add 2 integrals due to the circle you'll have the top and bottom part of it.
and it might be better to cut the cylinder by 2 lines so looking at the triangle side you can cut it at the center of the circle and get 2 symmetric sides so you can just do 2xsome integral to find the volume. |
| Nov24-07, 04:51 PM | #7 |
Well if I cut the cylinder in half diagonally, couldn't I just take the volume of the cylinder and then divide it by two? When you say cut the cylinder with two lines what do you mean?
And I have no idea how to set up the integral. >.< could you get me started please? |
| Nov24-07, 04:54 PM | #8 |
o yea you could just do that.
Use cylindrical coordinates to setup your integral and then just multiply it by .5 to find the volume. |
| Nov24-07, 05:15 PM | #9 |
could you help me set it up? thats the part im really bad at. Many thanks for discussing this problem with me. =)
| Nov24-07, 05:19 PM | #10 |
well you have [tex]r,\theta,z[/tex] in cylindrical coordinates.
r-? theta-? z-? z being the height and from what we've written you know what it is. so just find the r and the z and you can setup the integral. |
| Nov24-07, 05:30 PM | #11 |
theta would be 0 - 2pi?
z would be the height soo lets say 0 - a what would r be? |
| Nov24-07, 05:33 PM | #12 |
r would be 0 to the circle's radius, say R, and the height of the cylinder can be described in terms of R. So you can have the square when looking at it from 2 sides.
| Nov24-07, 05:41 PM | #13 |
what would the actual integrand be? [tex]rdrdz\theta[/tex]
r - 0-R theta - 0-2pi z - 0-R ? |
| Nov24-07, 05:47 PM | #14 |
no the z=2R because you need the diameter of the circle to = the height in order to get the square when looking at it from that side.
and yes the integrand will just be rdrdzd(theta). |
| Nov24-07, 05:55 PM | #15 |
[tex] 2\pi (\int \int rdrdz) [/tex]
0-2R for first integral and 0-R for second one. how would I go from there? the rdr is confusing me a little. |
| Nov24-07, 05:59 PM | #16 |
[tex]\int_0^{2\pi}d\theta\int_0^R rdr\int_0^{2R}dz[/tex]
the rdr just means integrate r w.r.t. r just like: [tex]\int x dx[/tex] |
| Nov24-07, 06:06 PM | #17 |
I got 2pi r^3 for final answer
after dividing by two. How does that sound? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Tricky Multiple integral word problem
| My tricky wave problem. ehh its probably not tricky. | Introductory Physics Homework | 15 | ||
| Tricky integral problem | Calculus & Beyond Homework | 3 | ||
| Tricky integral | Introductory Physics Homework | 18 | ||
| Distribute Word macros to multiple users | Computing & Technology | 0 | ||
| Tricky Integral | Calculus | 7 | ||
