Thread Closed
Rigid body acceleration question
Share Thread Thread Tools
Nov24-07, 07:04 PM   #1
The illustrated equilateral triangle is supported by two links. d = 0.5 m. At the illustrated position,[tex]\dot{\theta}= 9 rad/s[/tex] and [tex]\ddot{\theta}= 0 rad/s^2[/tex]. Find the magnitude of [tex]a_C[/tex].
3. The attempt at a solution
First I found the angle [tex]\beta[/tex]. This is the angle between point B and the horizontal
[tex]\beta=30[/tex]
Next I found all the angular speeds I am going to need: [tex]\omega_{DA}, \omega_{EB}, \omega_{AB}[/tex]
[tex]\omega_{DA}=9 rad/s[/tex] (Given)
[tex]\omega_{EB}=\omega_{DA} \frac{AD}{EB}[/tex] (AD and EB are essentially given)
[tex]\omega_{EB}=18 rad/s[/tex]
[tex]\omega_{AB}=-\omega_{DA}DA+ \omega_{EB}EB[/tex]
[tex]\omega_{AB}=0[/tex]
Next I found all angular accelerations I will need by assuming PGM:[tex]a_B=a_A+a_{B/A}[/tex]
[tex]\omega_{EB}^2(EB)j-\alpha_{EB}(EB)i=\omega_{DA}^2(AD)j+\alpha_{AB}(AB)sin(90-\beta)j-\alpha_{AB}(AB)cos(90-\beta)i[/tex]
I arranged the [tex]i[/tex] and [tex]j[/tex] components and solved finding:
[tex]\alpha_{EB}=93.53[/tex]
[tex]\alpha_{AB}=93.53[/tex]
Now I can find the accelerations of C:
[tex]a_Ci+acj=\omega_{EB}^2(EB)j-\alpha_{EB}(EB)i+\alpha_{AB}(BC)i[/tex]
Solve resultant of [tex]a_C[/tex] to equal 168 whereas it should be .202.
I'm not good at this at all and could have made some pretty big mistakes so bear with me.
Any help would be greatly appreciated!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Nov25-07, 05:58 PM   #2
anyone?
Thread Closed
Thread Tools
Similar Threads for: Rigid body acceleration question
Thread Forum Replies
Rigid body dynamics question Classical Physics 1
Equilibrium of a Rigid Body question Introductory Physics Homework 7
Dynamics Question, Planar rigid body/ Relative velocities Introductory Physics Homework 0
Plane Motion/Rigid Body Question Need Help. Engineering, Comp Sci, & Technology Homework 0
rigid body Introductory Physics Homework 1
