What Is the Spring Constant and Velocity of a Box on an Inclined Plane?
  • Thread starter Thread starter tachu101
    Incline
The problem involves a box sliding down an inclined plane attached to a spring, with considerations for friction. The goal is to determine the spring constant under two conditions (with and without friction) and the velocity of the box at a specific point along the incline.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss using conservation of energy to approach the problem, raising questions about the initial and final conditions, including the initial velocity and the height calculation. There is also a focus on the work done by friction and how to incorporate it into the energy equations.
Some participants have provided calculations for the spring constant and velocity, while others are seeking clarification on the methods used. There is an ongoing exploration of different interpretations of the equations and assumptions involved, particularly regarding the height and friction considerations.
Participants note discrepancies in height calculations, specifically whether to use sine or cosine for the height change. There is also a mention of the friction coefficient and its impact on the calculations, indicating a need for careful consideration of these factors in the problem setup.
tachu101
Given the incline plane, see picture, a box is let loose, attached to a spring in a relaxed position, the box moves down 2.75 meters. The variables: incline is at 32 degrees, the friction coefficient is .125 and the mass of the box is 17.4 kg. The length it slides is 2.75 meters.
Find the: spring constant (k) when friction is present?
spring constant (k) when friction is not present?
the velocity of the box when it is half way down the incline (so 1.375 meters)?
The teacher said that I could use conservation of energy to solve this and said that I could set it up in the following way
Work(in)= (mass)(gravity)(height final -height initial)+(1/2)(mass)(vf^2-Vo^2)+(friction)(distance)+(1/2)(k)(change in spring position^2)
I think that the Work goes to 0 , the Initial Velocity goes to 0, and the initial spring position is 0 ---- so----
0= (mass)(gravity)(height final -height initial)+(1/2)(mass)(vf^2-0)+(friction)(distance)+(1/2)(k)(change in spring position^2)
Is there a less cluttered way of solving this problem?
The initial height should be (2.75)(sin32)? Right?
The (distance) for the friction, and spring should be 2.75 because that is how far it goes?
Does the final velocity also go to 0, I am not sure about that?
Does anyone have an idea on how to go about solving this question?
Perhaps it will be easier to apply conservation of energy if you think of it like this:
(initial mechanical energy) + (work done by friction) = (final mechanical energy)
Mechanical energy is the sum of kinetic energy, gravitational PE, and spring PE. The work done by friction (where it exists) will be negative.
To find the work done by friction, first find the friction force.
Can anyone else get the same answers as me ---
k with friction -- 92.1179
velocity half way -- 3.587 m/s
k without friction -- 105.277
Anyone?
Why don't you show exactly how you got your answers.
I have gotten to
mgh=fs+1/2kx^2 ---- so ---- (17.4)(9.81)(2.75cos32)=(.125(17.4)(9.81)cos32)(2.75)+(1/2)(k)(2.75)^2
SO k= 92.117
then
I replug it into
To get a velocity of 3.587 m/s
Then to get without friction I just take friction out of the equation to get
mgh=1/2kx^2 where k then equals 105.277
tachu101 said:
I have gotten to
SO k= 92.117
The change in height should be 2.75*sin32, not cos32.
thank you I don't know what i was thinking there
  • · Replies 27 ·
11K
