Thread Closed
Blood Temperature Question
Share Thread
Nov25-07, 11:01 PM   #1
Question:
Blood can carry excess energy from the interior to the surface of the body, where the energy is dispersed in a number of ways. While a person is exercising, 0.671 kg of blood flows to the surface of the body and releases 1860 J of energy. The blood arriving at the surface has the temperature of the body interior, 37.0 °C. Assuming that blood has the same specific heat capacity as water, determine the temperature in degrees Celsius of the blood that leaves the surface and returns to the interior.
Attempt
From the equation:
I get the change in temperature. Since I am given initial temperature all I need to do is take the change in temperature and add the initial temperature:
(change)TEMP = Tf-Ti
Problem:
I'am not getting the right final temp.
PhysOrg.com science news on PhysOrg.com
>> A robot that runs like a cat (w/ Video)
>> Global cooling as significant as global warming, research shows
>> 'Chase and run' cell movement mechanism explains process of metastasis
Nov26-07, 06:49 AM   #2
Recognitions:
Homework Helper Homework Help
The blood at the surface of the body has lower temp. Are you taking the positive value of delta_t and subtracting it from 37?
Nov26-07, 07:57 AM   #3
Thanks problem solved.
Thread Closed
Similar Threads for: Blood Temperature Question
Thread Forum Replies
determine the temperature of the blood/ Heat problem Introductory Physics Homework 9
Question on Temperature Classical Physics 1
Temperature question Introductory Physics Homework 3
Question about Poisseuille's law and blood flow Classical Physics 1
A question about Smokers Blood...... Biology 2
