Energy + momentum conservation paradox
The discussion revolves around a paradox involving energy and momentum conservation in the context of an inelastic collision between two balls, where one ball is initially at rest. Participants explore the implications of conservation laws and the nature of kinetic energy during such collisions.
  • One participant describes a scenario where a moving ball collides with a stationary ball, resulting in both sticking together and raising a question about energy conservation.
  • Another participant clarifies that inelastic collisions do not conserve kinetic energy, emphasizing that while momentum is conserved, kinetic energy is transformed, possibly into thermal energy.
  • A participant questions whether the increase in temperature during the collision is due to the balls coalescing, indicating uncertainty about the conditions under which collisions are considered elastic.
  • Another participant defines elastic collisions as those where kinetic energy remains unchanged, contrasting this with inelastic collisions where kinetic energy is lost or gained, and notes that perfectly inelastic collisions are a specific case.
Participants generally agree that momentum is conserved in the collision, but there is disagreement regarding the implications for kinetic energy, with some emphasizing the transformation of energy into heat and others questioning the definitions of elastic and inelastic collisions.
The discussion highlights the complexity of energy transformations in collisions and the specific conditions under which different types of collisions are categorized. There is an unresolved aspect regarding the implications of temperature changes and the definitions of elastic versus inelastic collisions.
nocloud
here's the situation
one ball with mass m1 and velocity v1 collides with second ball with mass m2 and 0 velocity. they stick together and the resulting blob has mass m1+m2 and velocity v3 which can be easily found using m1v1+0 = (m1+m2)v3 by conservation of momentum
lets assume we are on level surface and potential energy is zero.
conservation of energy tells us that
.5m1v1^2+0 = .5(m1+m2)v3^2
thus, we have
v1/v3 = (m1+m2)/m1
and
v1/v3 = Sqrt[(m1+m2)/m1]
which is a contradiction.
Can anybody tell me what I am forgetting to consider here?
This is an inelastic collision, so kinetic energy is not conserved. Momentum is conserved, and you should be able to show that the collision reduces the kinetic energy of the system. Where did the extra energy go? The sticky collision made the balls get hotter than they were. (Energy is still conserved, but you have to take temperature into account.)
Is that simply because they coalesce?
We take collisions to be elastic a lot in mechanics questions in maths, but I can't remember whether that was only when they don't coalesce...
I guess it can only be elastic if you are using Newton's law of impacts, and e=1?
The definition of an elastic collision is one in which the kinetic energy remains unchanged. Kinetic energy can be gained (a ball and a contact explosive; a hyperelastic collision) or lost (a ball and a glob of glue; an inelastic collision) as a result of a collision. A collision in which the objects stick together is the extreme example of an inelastic collision, and hence the special name "perfectly inelastic collision".
  • · Replies 30 ·
