Why Is the Moment Negative in Case 2 Despite Using the Right Hand Rule?
The discussion clarifies the determination of moment direction using the right-hand rule in physics. Specifically, when counterclockwise (ccw) is defined as positive, the moment vector points out of the page in the positive Z direction. Consequently, clockwise (cw) moments are negative, pointing into the page in the negative Z direction. In the examples provided, the first two moments are negative, while the last moment is positive based on this convention.
  • Understanding of moment vectors in physics
  • Familiarity with the right-hand rule
  • Knowledge of counterclockwise and clockwise moment conventions
  • Basic grasp of vector direction in three-dimensional space
  • Study the application of the right-hand rule in various physics problems
  • Explore the concept of moment vectors in different coordinate systems
  • Review examples of moment calculations in static equilibrium
  • Learn about the implications of moment direction in engineering applications
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone involved in teaching or learning about moment calculations and vector analysis.
engineer_dave
How do u find whether the moment is negative or positive in the three examples shown?? Even if you use the right hand rule, for case 2 i have seen that the moment is negative and not positive. I am taking counter clockwise as positive moments. Please help out. Thanks!
If you take ccw as positive, then the moment vector points out of the page toward you, using the right hand rule, in the positive Z direction. It follows that cw moments are then negative, pointing in the negative Z direction into the page away from you. So the first 2 moments, being cw are negative, and the last, being ccw, is positive, per your chosen convention.
  • · Replies 31 ·
10K
12K
  • · Replies 18 ·
