Thread Closed
average force exerted on ball by wall at angle
Share Thread
Nov26-07, 06:16 PM   #1
a 8kg steel ball strikes a wall with a speed of 11.7 m/s at an angle of 35.3 degrees with the normal to the wall. it bounces off with the same speed and angle as shown in the picture.
http://img405.imageshack.us/img405/7733/asdfkf7.jpg
If the ball is in contact with the wall for 0.297 seconds, what is the magnitude of the average force exerted on the ball by the wall? Answer in N
2. Relevant equations
3. The attempt at a solution
Ft = mv
F(0.297) = 8 * 11.7
F = 315.15 kg* m/s^2 or N but thats if its a linear problem
Angle wise
Horizontal speed of 11.7 m/s
Cos 35.3 = x / 11.7
x = 9.549 m/s
Extra info
Vertical speed of 11.7 m/s
sin 35.3 = y / 11.7
y = 6.761 m/s
Ft = mv
F(0.297) = 8 * 9.549 m/s
F = 257.2069 N
is that right?
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Nov26-07, 08:05 PM   #2
Admin
Ft = mv
F(0.297) = 8 * 11.7
Ft = mv
F = 257.2069 N
Be careful here. Note that in the y direction, the y-component of velocity does not change. On the other hand, the x-component of velocity does change, in direction, but not in magnitude. The magnitudes in the x- and y- directions are correct.
Nov26-07, 08:37 PM   #3
Quote by Astronuc View Post
Does it matter if I include the y direction in the equation? Would I need to make two equations one going toward the wall and another going away? But then if I equal to them wouldn't it be zero?
Thread Closed
Similar discussions for: average force exerted on ball by wall at angle
Thread Forum Replies
Force exerted by a ball to Introductory Physics Homework 10
the angle @ which the particle hits the wall Introductory Physics Homework 3
ball being thrown against a wall Introductory Physics Homework 10
Steel Ball off the Wall Introductory Physics Homework 3
Average wall stress in an aneurysm Introductory Physics Homework 1
