Exact Definition of Riemann Integral
The discussion centers on the Riemann Integral, specifically examining the integrability of the function f(x,y) = xy³ / (x² + y²)², defined as 0 at the origin. Participants explore the implications of the function's behavior near the origin and the conditions under which the integral g(y) = ∫₀¹ f(x,y) dx is well-defined.
  • Some participants note that f(x,y) is smooth everywhere except at the origin, raising questions about its integrability due to the discontinuity at that point.
  • Others argue that the discontinuity at the origin is a set of measure zero, suggesting that it does not prevent the integral from existing.
  • A participant mentions the importance of limits in multiple dimensions, suggesting that approaching the origin via different paths should yield consistent results.
  • One participant proposes using polar coordinates to simplify the analysis of the function near the origin.
  • Another participant emphasizes that the function h_y(x) = f(x,y) is continuous at 0 for fixed y, which may support the argument for the well-defined nature of g(y).
  • There is a correction regarding the conditions for integrability, with a participant pointing out that continuity almost everywhere is necessary but not sufficient, citing the example of f(x) = 1/x.
  • Some participants discuss the definition of Riemann sums and the conditions under which a function is Riemann integrable, noting that boundedness is also a requirement unless considering improper integrals.
Participants express differing views on whether the function's discontinuity at the origin affects the integrability of g(y). While some argue that the measure zero property allows for integrability, others raise counterexamples and conditions that complicate the discussion. Overall, there is no consensus on the implications of the discontinuity for the integral's existence.
Limitations include the dependence on the definitions of integrability and continuity, as well as the unresolved nature of the mathematical steps involved in approaching the origin via different paths.
Mr.Brown
Hi I recently stumbled upon this:
I know that the Riemann Integral is defined for every piecewise continouus curve.
But now suppose you´re asked the following:
you are given [tex]f(x,y)=\frac{xy^3}{(x^2+y^2)^2}[/tex] with additional Definition
f(0,0)=0. ( It´s a textbook problem :) )
Now surely f(x,y) is smooth everywhere except for the origin. So I tried to show that f(x,y) goes to 0 in the origin but it doesn´t goes to 1/4(easy to show by setting x=y because f(x,y)=1/4 for x=y).
So the book asks to proof that the function [tex]g(y)=\int_{0}^{1}f(x,y)dx[/tex] is well defined on the real line.
I would intuitively say no because of the discontinuity at the origin but otherwise the origin is a set of measure zero.
So how does that definition go ?
you say approaching the origin via y=x gives you 1/4, remember that limits in n-dimensions need to give the same answer no matter WHICH way you goto the origin. Now, i haven't worked with several variables in a while so I'm not going to attempt it although looking at the denomintator it looks like moving to polar coordinates would simplify matters.
the precise definition of reimann integration can be found on wikipedia, the darboux definition is the most practical for analytic purposes but in this case all you need to know is that the single discontinuity at the origin will NOT prevent the integral from existing. Regarding measure you are correct, a function f is integrable on a set E iff f is continuous almost everywhere on E.
hope this helps
oh yeah i forgot to say, try approaching the origin via the parabola y=x^2.
As you know, f(x,y) (with y held constant) is continuous except when x=y=0. This is a single point, so it is of measure zero. What else needs to be satisfied for a function to be Riemann integrable on a set [a,b]?
As for the exact definition of the Riemann Integral, I don't think it'll help you here, what you really want is the Riemann Lebesgue Theorem, but
A Riemann Sum
[tex]R(f,P,T) = \sum_1^n f(\hat x_i)\Delta x_i[/tex] where [tex]P=\{x_1, \dotsc, x_n, x_{n+1}\}[/tex] is a partition of the interval [a,b] (in this sense, a partition is an ordered set of points in the interval [a,b] with [tex]x_1 = a[/tex] and [tex]x_{n+1} = b[/tex]) and [tex]T = \{\hat x_1, \dotsc, \hat x_n\}[/tex] is a set of points interspersed between the partition points of P (i.e. [tex]x_1 \leq \hat x_1 \leq x_2 \leq \dotsb \leq x_n \leq \hat x_n \leq x_{n+1}[/tex])
We defined [tex]\Delta x_i = x_{i+1} - x_i[/tex]
The mesh of P is the largest [tex]\Delta x_i[/tex]
The Riemann Integral is the limit of the Riemann Sums as the mesh of P goes to 0
In other words, although you learn in Calculus that the Riemann Sum is defined as dividing the interval up evenly and then picking a point at one of the end points of your divisions, and then the Riemann Integral is defined by the limit as the size of the divisions go to 0, the actual definition of a Riemann Sum allows you to divide the interval up however you want and place points anywhere in the divisions. You still take the integral to be the limit as the size of the divisions goes to 0.
Anyway, like I said, this is probably completely useless to you. Look up the Riemann Lebesgue Theorem.
Not entirely true, you're missing something. The function [tex]f(x) = 1/x[/tex] is not integrable on any interval containing 0 even though it is only discontinuous at 0.
Edit: Mr. Brown: also keep in mind that because your function f is continuous everywhere except at (0,0), you only need to worry about g(0)
Since it hasn't been mentioned yet, I just wanted to point out that h_y(x) = f(x,y) is actually continuous at 0 (and everywhere else). For nonzero y, the denominator is nonzero. For y = 0, h_y(x) = 0 everywhere. I think for the given problem, that's all he needed to show.
Correction.. [tex]g(y)=\int_{0}^{1}h_y(x)dx[/tex] is well defined because h_y is continuous for fixed y.
f needs to be bounded, unless you are considering it as an improper integral.
just look at the definition. this is trvially true with no high powered theory needed of any kind. the only interesting value is x=0 where the function is dead zero. done.
  • · Replies 16 ·
  • · Replies 20 ·
