How Does Friction Affect the Velocity of a Mass on a Spring?
The discussion revolves around a mass-spring system where a 0.2 kg mass is attached to a spring with a spring constant of 10 N/m, hanging vertically. The mass experiences a constant frictional force of 5 N as it moves vertically and makes contact with a wall. Participants are exploring the work done on the spring and the velocity of the mass as it passes through the equilibrium position after being pulled down by 1 m.
  • Mixed
  • Participants attempt to calculate the work done on the spring and the speed of the mass at the equilibrium position. There are discussions about the conversion of elastic potential energy to kinetic energy, the effects of friction, and the need to account for gravitational potential energy. Some participants express confusion about the derivation of certain equations and the assumptions being made.
Several participants have provided insights into the relationship between elastic potential energy, kinetic energy, and work done against friction. There is an ongoing exploration of how to incorporate the work done by friction and gravitational potential energy into their calculations. Some participants are questioning the correctness of previous calculations and assumptions, indicating a productive exchange of ideas.
Participants are navigating the complexities of energy conservation in the presence of friction and are uncertain about how to quantify gravitational potential energy without specific height information. The discussion reflects a mix of correct and incorrect reasoning, with no clear consensus reached yet.
henry2221
Question:
A 0.2 kg mass is attached to a spring k = 10 N/m) and hangs vertically near the Earth's surface (g = 9.81 m/s2 ). The mass makes contact with a wall as it moves vertically and a constant frictional force of magnitude 5N acts on the mass as it moves.
a) Calculate the amount of work required to pull the spring down by 1 m.
b) Calculate the speed of the mass as it passes through the equilibrium position after being pulled down by 1 m.
Eq'n
U = (1/2)k x^2
Attempt:
a) W = U = (1/2)k x^2
(1/2)(10 N/m) (1m)^2
= 5 N*m
= 5 J
I am lost on part b, someone suggested
v = sqrt(k/m) * x
... But I have no clue where they derived this equation...
I tried
K = 1/2 m v^2
v = sqrt(2K/m)
...But I believe this is incorrect... suggestions?
all the elastic potential energy is converted back into kinetic. so equate Eelastic - Ethermal = Ekinetic and solve. but you have to also consider energy lost due to friction, so put that in the equation too.
wait... is this assuming that I did part a correctly? or...
Part a must include the work associated with the frictional force of 5 N over 1 m, in addition to the mechanical energy in the spring.
In part b, when the spring recoils, the friction is again present, so not all the spring energy will be transformed into kinetic energy.
So I am assuming that its:
W = Us + Ug + 5Nm
However how would I find Ug without knowing it's height?
The mass changes elevation by 1 m, from the equilibrium position, and since the mass is going down, it's gravitational potential energy (GPE) decreases. When the mass goes up, it's GPE increases.
New attempt:
Us = W = U = (1/2)k x^2
= 5 N*m
Ug = (0.1 kg)(1m)(-9.8 m/s^2)
= -.98 J
W= Us + Ug+ (-5J)
5J + (-98 J) + (-5J)
= -.98 J
b) W = E - Wnc (Work energy Theorem for Systems)
W = 0 Because there is no internal nonconservative forces.. I still haven't a clue where to start with this one...
Therefore E:
OK, when the spring is being pulled down, the friction and spring force act in the same direction. Part of the work being done goes into the stored mechanical energy in the spring and part is used to overcome friction.
When the spring recoils, the spring pulls (acts up) but friction is acting down.
New attempt:
= 5 N*m
= -.98 J
Uf = 5J
W= Us - Ug + (5J)
5J -.98 J + 5J
= 9.8 J
So far, is this correct?
  • · Replies 17 ·
