Another problem - time dependent perturbation and transition probabilities
The discussion revolves around a problem in time-dependent perturbation theory, specifically calculating transition probabilities for a harmonic oscillator subjected to a perturbation. The perturbation is defined as V(x,t)=βx exp(-γt), and the participants are tasked with determining the transition probability from the ground state to excited states using the properties of Hermite polynomials and the recursion relations associated with them.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants express confusion about where to start and how to apply the recursion relation and the matrix elements involved in the transition probability calculation. Some are considering the use of the Fermi Golden Rule, while others suggest a more fundamental approach to time-dependent perturbation theory. Questions about the interpretation of the matrix element and the use of Dirac notation are also raised.
The discussion is ongoing, with participants sharing their thoughts and attempts to understand the problem. Some have offered hints regarding the use of recursion relations and matrix elements, while others are still grappling with the concepts and seeking further clarification. There is no explicit consensus yet, but there are indications of productive direction as participants explore different aspects of the problem.
Participants mention feeling lost and confused about the recursion relation and its application. There are references to the orthogonality of eigenstates and the need for a deeper understanding of Hermite polynomials. Some participants are also looking for additional resources to aid their understanding.
Erwin Kreyszig
(the actual question is now as an attachment)
Assuming that the perturbation V(x,t)=[tex]\beta[/tex]x exp(-[tex]\gamma[/tex] t) is applied at t = 0 to a harmonic oscillator (HO) in the ground state, calculate to the first approximation the transition probability to any excited state n[tex]\geq[/tex]1 (here beta and gamma are constants). HO eigenstates are expressed in terms of the Hermite polynomials, H[tex]_{n}[/tex](y), as [tex]\left\lfloor[/tex]n[tex]\right\rangle[/tex]=[tex]\left([/tex][tex]\alpha[/tex]/(2[tex]^{2}[/tex] n! [tex]\sqrt{\pi}[/tex][tex]\right)[/tex][tex]^{1/2}[/tex] e[tex]^{-\alpha^{2} x^{2}}[/tex] H[tex]_{n}[/tex]([tex]\alpha[/tex]x) with [tex]\alpha[/tex]=[tex]\sqrt{M\varpi / \hbar}[/tex] , M is the mass of the oscillator, and [tex]\varpi[/tex] is the frequency. Use the recursion relation 2yH[tex]_{n}[/tex] = H[tex]_{n+1}[/tex] (y) = 2nH[tex]_{n-1}[/tex], and orthogonality of different eigenstates.
That is the question, but what i am struggling on this question is, where to start, lol. I am completely lost as to what the recursion relation is, and how to go about finding the transition probability. Please, any help would be great, maybe a little more advise on what to read or what steps i need to take to find this probability.
As i said, i not had much/any luck with this. i am truly struggling. I am aware the question is part of a time dependent perturbation and i am looking to find a probability of an electron making a jump from one energy level to another, but there i find myself scratching my head.
ANy help or advise on how to approach the problem would be greatfully recieved.
Thanks for your help...again EK
Do you know a formula for the transition probability? That would be a good place to start.
I have the equation for the probability, "Fermi goldern rule" But the matrix element through me a little. is that the expectation value for the event occurrence?
Thanks for your help EK
This is not a "Golden Rule" problem, you need a more basic formula of time-dependent perturbation theory.
But it will involve a matrix element of V(x,t) between the initial state (the ground state) and the final state (an energy eigenstate labeled by n). Since V(x,t) is proportional to x, you need to compute [itex]\langle n|x|0\rangle[/itex]. Any idea how to use the hints you were given to do that?
Not really, i have not encountered the recursion relation, and am fairly confused about that. Is the eqauation for the hamiltonian just the [ hamiltonian for the stationary state + a the pertibation ] ? I am truly at a loss atm. Thanks
EK
You may be confused by the Dirac bra-ket notation. It means
[tex]\langle n|x|0\rangle = \int_{-\infty}^{+\infty}dx\,\psi^*_n(x)x\psi_0(x)[/tex]
Of course, you know that, without the factor of x in the middle, the energy eigenfunctions are orthogonal:
[tex]\langle n|n'\rangle = \int_{-\infty}^{+\infty}dx\,\psi^*_n(x)\psi_{n'}(x)=\delta_{nn'}[/tex]
Perhaps now you can see how the recursion relations helps ...
I understand the Kronecker and the dirac notation, but the recursion relation still has me. so far on this problem, i am thinking about the Probability being
[tex]\frac{\left|H''\right|^2}{2 \hbar^2} g(w)t[/tex]
where g(w) being the density of states.
And in this case, we only deal with the ground state and the 1st state, right? As from that relation that would only give me one part of that equation. I.e. [tex]H_{0}[/tex] gives only the [tex]H_{n+1}[/tex] term?
Thanks for your continued help.
EK
I'm doing the same problem - Erwin, are you at Loughborough?
The problem is, using the orthogonality conditions and the recursion relations...
Basically, you get an integral (I think) of this form:
INT(-inf..inf) exp(-2a^2 * x^2) Hn Ho dx
Even if this is the correct method, I don't know what to do next.
PS - Apologies for the ASCII maths, I'm re-downloading LaTeX presently.
Yeah Loughborough, i am pretty sure you take the matrix element of perturbation, at t=0, then find the constant [tex]C_{n}[/tex] with that. Then from that you can find the probability. Maybe...
That or you go straight from [tex]V_{nk}[/tex] to probability
EK
Can you use the recursion relation to express [itex]x\psi_0(x)[/itex] in terms of other energy eigenstates?
And [tex]\frac{\left|H''\right|^2}{2 \hbar^2} g(w)t[/tex] is not correct. This is a "golden rule" formula that does not apply to this problem.
I am lost as to how to use the recursion relation to be honest. I am thinking you use this to find the wave function of the problem. Is there any good internet sites or books in which the recursion relation and hermite polynomials are described fully? I am struggling to find out how to use them.
Thank you EK
Using Hermite, xH1 = (1/2)H2 + nHo
But that doesn't really help.
Thanks for your help Avodyne, i think i was being a bit retarded. now i know what i am looking for using the recursion relation, i should be fine. I think i got an answer for the solution, and its less that 1 so i am happy that its sensible. Thank you again.
EK
Dakes: it helps a lot! See my post #6.
EK: you're welcome!
