What Is the Final Temperature When Ice Is Added to Lemonade?
The final temperature when a 1.74 kg ice cube at -10.2°C is added to 3.95 kg of lemonade at 20°C is 0.00°C, with some ice remaining. The calculations involved determining the heat required to raise the temperature of the lemonade and the heat needed to warm and melt the ice. The total heat absorbed by the ice (619,993.32 J) exceeds the heat released by the lemonade (330,694 J), resulting in leftover ice. The process confirms that the final temperature stabilizes at 0.00°C, with the remaining ice needing further calculation to determine its mass.
  • Understanding of heat transfer principles (Q = mCT)
  • Knowledge of latent heat of fusion (Lf = 33.5e4 J/kg)
  • Familiarity with specific heat capacities (Cwater = 4186 J/(kg x K), Cice = 2090 J/(kg x K))
  • Basic algebra for solving energy balance equations
  • Calculate the mass of ice remaining after reaching thermal equilibrium
  • Explore the concept of energy conservation in phase changes
  • Investigate the effects of varying initial temperatures on final equilibrium
  • Learn about specific heat capacities of other substances for comparative analysis
Students studying thermodynamics, physics educators, and anyone interested in heat transfer and phase change calculations.
Nghi
A large punch bowl holds 3.95 kg of lemonade (which is essentially water) at 20 C. A 1.74 kg ice cube at -10.2 C is placed in the lemonade. What is the final temperature of the system, and the amount of ice (if any) remaining? Ignore any heat change with the bowl of surroundings.
Q = mCT
Q = mLf (Lf = Latent heat of fusion)
Lf = 33.5e4 J/kg
To find the final temperature, I figured out the amount of heat it would take to bring water from 20.0 C to 0.00 C. It's basically plug and chug.
Qwater = mCT
= (3.95)(4186)(20)
= 330,694 J
Then I found the amount of heat it would take to bring ice from -10.2 C to 0 C. I also calculated the amount of heat it wold take to melt the ice (using latent heat).
Qice = mCT
= (1.74)(2090)(10.2)
= 37,093.32 J
Qice = mLf
= (1.74)(33.5e4)
= 582,900 J
Qice total = 619,993.32 J
Then I subtracted Qice from Qwater, and here was what I got:
Q = Qw - Qi
= 330,694 - 619,993.32
= -289,299.32 J
Since the leftover heat is negative, it means that ice is left over. So that would mean that the final temperature of water would be 0.00 C. I don't know if the thinking process is correct (Can someone help me verify this?), but I do know that the final answer is correct.
The problem I'm having is the amount of ice remaining. Since delta Q is negative, it would mean that ice would INCREASE, right? But I don't know how to solve it. :/
Remember the Q lost by the cooling water must be equal to the Q gained by the warming ice + the Q that melts the ice.
So the difference between the mcT(water) and mcT (ice) would give you the amount of heat still available to melt the 0 degree ice. Use that to find the mass of the ice that melted which will lead to the amount that still remains.
Thank you so much! :)
  • · Replies 16 ·
