Register to reply
Eigenvalues and Eigenspinors
by Rahmuss
Tags: eigenspinors, eigenvalues, solved
Share this thread:
Rahmuss
#1
Nov30-07, 09:47 AM
P: 223
(a) Find the eigenvalues and eigenspinors of [tex]S_{y}[/tex].
2. Relevant equations
[tex]\hat{Q}f(x) = \lambda f(x)[/tex]
3. The attempt at a solution
The above equation wasn't given specifically for this problem; but that's the one I'm trying to use.
[tex]\hat{Q}f(x) = \lambda f(x)[/tex] --> [tex]\frac{\hbar}{2}\left(^0_i ^-i_0\right) f(x) = \lambda f(x)[/tex]
But here is where I'm stuck. I'm not sure what I would be using for my function [tex]f(x)[/tex]. I guess the fact that it's a matrix kind of throws me off too.
For the second part (finding the eigenspinors of [tex]S_{y}[/tex]), so far I have:
[tex]X_{+}y = \frac{\hbar}{2}\left(^{0}_{i} ^{-i}_{0}\right)[/tex] --> [tex]\frac{\hbar}{2}\left(^{0}_{i}\right)[/tex]
P.S. I'm not quite sure how to do matrices in this tex code. Does anyone know how?
Phys.Org News Partner Science news on Phys.org
Sapphire talk enlivens guesswork over iPhone 6
Geneticists offer clues to better rice, tomato crops
UConn makes 3-D copies of antique instrument parts
nrqed
#2
Nov30-07, 09:56 AM
Sci Advisor
HW Helper
P: 2,887
Quote Quote by Rahmuss View Post
f(x) is not a function here but a column vector. Just replace it by a column vector with entries "a" and "b" which are two constants to be determined.
basically, this is a matrix algebra problem. You simply have to find the eigenvalues and eigenvectors of the matrix S_y. Just proceed as you did in linear algebra (find teh roots of the characteristic equation, etc)
nrqed
#3
Nov30-07, 09:59 AM
Sci Advisor
HW Helper
P: 2,887
Here is an example (click with yoru mouse on the tex output to see the code I typed in)
[tex]
\begin{pmatrix}
1 & 1 & 1 \\
1 & \omega & \omega^2 \\
1 & \omega^2 & \omega
\end{pmatrix} [/tex]
Rahmuss
#4
Nov30-07, 10:25 AM
P: 223
nrqed - Thanks. So now I have done:
[tex]\frac{\hbar}{2}\left( \begin{array}{cc}0 & -i\\i & 0\end{array}\right) \left(^{a}_{b}\right) = \lambda \left(^{a}_{b}\right)[/tex] --> [tex]\left(^{ai\frac{\hbar}{2}}_{-bi\frac{\hbar}{2}}\right) = \left(^{a\lambda}_{b\lambda}\right)[/tex]
[tex]\lambda = \pm i\frac{\hbar}{2}[/tex].
Is that correct? Also, for the second part, can I assume since you did not respond to that section, that it is also correct? Thanks again for the help.
nrqed
#5
Nov30-07, 10:46 AM
Sci Advisor
HW Helper
P: 2,887
Check this carefully.. Do you see the mistake in the above?
Your
final answer for the lambda is correct but assuming that it's not a typo in what you wrote, you could not have obtained those values of lambda from the equation you wrote. Hwo did you get your values of lambda?
For the second part (finding the eigenvectors) we must first get the eigenvalues so let's clarify this first.
Just a question: do you recall how to find eigenvalues of matrices? The best way is to find the characteristic equation which gives a polynomial in lambda and to find the eigenvalues.
Count Iblis
#6
Nov30-07, 10:53 AM
P: 2,158
It is easier to simply rotate the eigenvectors of [tex]\sigma_z[/tex] around the x-axis.
Rahmuss
#7
Nov30-07, 11:05 AM
P: 223
Well, for my values I just set:
[tex]ai\frac{\hbar}{2} = a\lambda[/tex] ---> [tex]\lambda = i\frac{\hbar}{2}[/tex]
and
[tex]-bi\frac{\hbar}{2} = b\lambda[/tex] ---> [tex]\lambda = -i\frac{\hbar}{2}[/tex]
Oh, and yes, I see the mistake. My a and b are switched in the second equation with vectors; but it's still the same right?
Rahmuss
#8
Nov30-07, 11:10 AM
P: 223
nrqed - I remember the characteristic equation being somthing like:
[tex]y'' + 4y' + 4y = 0[/tex] ---> [tex]r^2 + 4r + 4[/tex]
And then you solve for r to get the values you need. And as for the eigenvalues of matrices, I remember something like:
[tex]\left(\begin{array}{cc}1-\lambda & 0\\0 & -1-\lambda \end{array}\right)[/tex]
Count_Iblis - I'm not sure what you mean.
Marco_84
#9
Nov30-07, 11:16 AM
P: 173
i think it is not correct, the secular equation reads: Lambda^2-1=0 so lambda=+1 or-1. i've putted h=4pi. Now u have two eigenvalues in a space of dimension 2 so the diagonalized matrix is Sz=diag(1,-1) and the eigenvectors are |+> and |-> read (1,0) and (0,1) but in column. (Spin up or Spin down). This exercice suggest u that it is forbidden to simoultaneusly diagonalize Sy and Sz. To find a good basis for the angular momentum u should switch the axis at the occurence. the important u have to know is what follow ->>> [Sx,Sy]=Sz and cycles. read abou the SU(2) algebra... the pauli matrices.
nrqed
#10
Nov30-07, 11:25 AM
Sci Advisor
HW Helper
P: 2,887
and
But then you get lambda is equal to both i hbar/2 and -i hbar /2 which is impossible!
yes you switched them which is why it does not work.
If you do it correctly, you can't solve anything. You have two equations for two unknowns: a,b and lambda and you are stuck.
What you are doing here is the second step of the calculation: finding the eigenvectors once you know the eigenvalues. You must first find the eigenvalues by solving the characteristic equation.
nrqed
#11
Nov30-07, 11:29 AM
Sci Advisor
HW Helper
P: 2,887
This is in a different context and is not what I am referring to.
That's what I have in mind except you wrote the wrong expression You need to solve [tex] det(S_y - \lambda) =0 [/tex]. What you wrote above is not S_y - lambda (here I mean lambda times the identity matrix).
Rahmuss
#12
Nov30-07, 11:58 AM
P: 223
nrqed - Right! Yeah, I didn't mean for my example of finding the eigenvalues as the problem that I was trying to solve. So...
[tex]\begin{pmatrix}-\lambda -i\frac{\hbar}{2} \\i\frac{\hbar}{2} -\lambda \end{pmatrix} = 0[/tex]
[tex]\lambda^{2} =\frac{\hbar^{2}}{4}[/tex] ---> [tex]\lambda = \pm \frac{\hbar}{2}[/tex]
Is that right???
nrqed
#13
Nov30-07, 12:07 PM
Sci Advisor
HW Helper
P: 2,887
Is that right???
That's right. Now for each of those eigenvalues you go back to the eigenvalue equation and find the corresponding two eigenstates.
Count Iblis
#14
Nov30-07, 12:39 PM
P: 2,158
Rahmuss,
Just consider cheating a bit. What you call the x, y and z direction is arbitrary, it cannot affect the physics. So, it immediately follows the eigenvalues of S_y must be the same as S_z as the eigenvalues are the possible values you can observe when measuring the spin and the particle doesn't care what direction you call x, y or z.
Now, what we want to do is to express the eigenvectors of Sy in terms of the eigenvectors of Sz. But because Sy and Sz are the same up to a rotation, you can just as well rotate the eigenvectors of Sz. So, we need to know how spinors transform under rotations.
Suppose you have some particle with spin. Suppose that you rotate your coordinate axis by [tex]\bf{\theta}[/tex] (magnitude = angle and direction is rotation axis, righthand rule convention). The particle itself is not affected in any way by the rotation (this is called a passive rotation). It can be shown that:
[tex]|s'>=\exp\left( \frac{i}{\hbar} \bf{S}\cdot\bf{\theta}\right)|s>[/tex]
where |s> is the spin of the particle and |s'> is the transformed spin. E.g. if you rotate by pi/2 around the y-axis, then the new z-direction will point in the direction of the old x-direction. A particle with spin polarized in the old z-direction will be polarized in the minus x-direction. If you take theta = pi/2, S = S_y and |s> |+> in the above formula, you get |s'> = the state corresponding to a particle polarized in the minus x-direction.
To solve this problem we want to rotate the coordinate axis such that the new y-direction will point in the direction of the old z-axis. The eigenvectors of Sz will then transform into the eigenvectors of Sy. This means that you have to rotate around the x-axis by pi/2:
[tex]|s'>=\exp\left( \frac{i}{\hbar} S_{x}\frac{\pi}{2}\right)|s>[/tex]
If you work this out for spin 1/2 using properties of Pauli matrices you get
[tex]\exp\left( \frac{i}{\hbar} S_{x}\frac{\pi}{2}\right) =\frac{\sqrt{2}}{2}\begin{pmatrix}1&i\\i&1\end{pmatrix}[/tex]
nrqed
#15
Nov30-07, 12:43 PM
Sci Advisor
HW Helper
P: 2,887
Quote Quote by Count Iblis View Post
Rahmuss,
This is all good but I am not sure if it's the right level for the OP. It's always tricky to answer questions at the right level (people have to learn to walk before lerning to run ). I felt that from the comments made, it was more appropriate to first learn to find the eigenavlues and eigenvectors explicitly. But if this is clear top the OP, that's a good way to do it!
Count Iblis
#16
Nov30-07, 12:52 PM
P: 2,158
So, you see that |+> = (1,0) transforms into 1/sqrt(2) (|+> + i |-> ) = 1/sqrt(2) (1,i) so this is the eigenvector of Sy with eigenvalue h-bar/2 and |-> = (0,1) transforms into 1/sqrt(2) (i,-1) which is the eigenvector corresponding to the eigenvalue of -h-bar/2
Of course, the moment you know one, the other is fixed as the eigenvectors are orthogonal.
Count Iblis
#17
Nov30-07, 12:57 PM
P: 2,158
Quote Quote by nrqed View Post
I agree that the student must master linear algebra first. But this means that the student must still learn about coordinate transformations, unitary transformations etc. And this problem is suitable to demonstrate coordinate transformations as well.
nrqed
#18
Nov30-07, 01:34 PM
Sci Advisor
HW Helper
P: 2,887
Very true.
Regards
Patrick
Register to reply
Related Discussions
Diagonalization, eigenvectors, eigenvalues Precalculus Mathematics Homework 4
Approximate eigenvalues Calculus & Beyond Homework 1
Approximate eigenvalues Linear & Abstract Algebra 1
Permutation of eigenvalues Linear & Abstract Algebra 0
QM - Eigenspinors Advanced Physics Homework 17
