Absorption of Light and Energy Conservation
The discussion centers on the absorption of photons by atoms and the implications for energy and momentum conservation. When an atom absorbs a photon of energy E, an electron transitions to a higher energy level, resulting in a change in potential energy equal to the photon's energy. The confusion arises regarding the momentum transfer from the photon to the atom, which leads to kinetic energy and potential thermal energy increases. However, the momentum of the photon is negligible compared to the mass of the atom, similar to how the Earth does not noticeably recoil from raindrop impacts.
  • Understanding of photon energy and electron transitions
  • Basic knowledge of momentum conservation principles
  • Familiarity with thermal energy concepts
  • Knowledge of electromagnetic (EM) fields and their effects on atoms
  • Study the principles of photon absorption and electron energy levels in quantum mechanics
  • Explore the relationship between momentum and kinetic energy in physics
  • Investigate the effects of thermal energy on atomic and molecular behavior
  • Learn about conservation laws in physics, particularly in quantum systems
Physical science teachers, students studying quantum mechanics, and anyone interested in the principles of energy conservation and atomic interactions.
scienceteacher
Hello everybody. I apologize if this question is a little trivial compared to a lot of the threads posted, but I am an 8th grade science physical science teacher and am a little confused about some of the material.
From what I understand, if an atom absorbs a photon of energy E, then an electron will jump to a higher energy level. The change in potential energy that results from the EM field will be equal to the energy of the absorbed photon. All this I got from my understanding of spectral lines. Where I am confused is that I know the photon also has momemntum which must be conserved. If the photon transfers is momentum to the atom, the atom must have some Kinetic energy, which on a larger scal will translate to an increase in thermal energy. This seems to violate energy conservation. I know I must be missing something...what is it??
Thanks for the help Y'all!
Science news on Phys.org
The atom does "recoil". However, you need to compare the momentum of a "typical" photon that is involved in such absorption versus the mass of the atom. For example, you don't see the Earth recoiling when raindrops hit its surface, do you? Even a larger comet hitting the Earth doesn't cause it to recoil much.
Zz.
  • · Replies 20 ·
  • · Replies 17 ·
