Legrange->System of equations
  • Thread starter Thread starter adm_strat
The problem involves finding the minimum distance between points on the graphs of the functions f(x) = x² and g(x) = ln(x). It includes approximating the coordinates of these points and exploring the relationship between their derivatives.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss using Lagrange multipliers and alternative methods for minimizing the distance function. Some express difficulty in solving the resulting system of equations, while others suggest using software tools like Mathematica for assistance.
There are various approaches being explored, including direct minimization and reformulation of the problem. Some participants have shared results from software attempts, while others are questioning the effectiveness of their methods. Guidance has been offered regarding potential substitutions and alternative formulations.
Participants note challenges with nonlinearity in equations and the constraints of using software for solving complex systems. There is also mention of imposed homework rules regarding the use of computational tools.
adm_strat
[SOLVED] Legrange-->System of equations
Suppose (a,b) is on the graph of [tex]f(x)=x^{2}[/tex] and (c,d) is on the graph of g(x)=ln(x)
a) Accurately approximate the minimum distance between (a,b) and (c,d)
b) Accurately approximate (a,b) and (c,d)
c) What is the relationship between f'(a) and g'(c)
Just a Legrange
The function that needs to be minimized is [tex]\sqrt{(a-c)^{2} + (b-d)^{2}}[/tex]
Which can be left as [tex](a-c)^{2} + (b-d)^{2}[/tex] because they will both be minimized at the same place
The Legrange:
[tex]L(a,b,c,d,\lambda ,\mu )=(a-c)^{2} + (b-d)^{2} - \lambda (a - b^{2}) - \mu (b-ln(d))[/tex]
This gave me the six equations:
[tex]L_{a}= 2a - 2c - \lambda = 0[/tex]
[tex]L_{b}= 2b - 2d - 2\lambda b = 0[/tex]
[tex]L_{c}= 2c - 2a - \mu = 0[/tex]
[tex]L_{d}= 2d - 2b - \frac{\mu }{d}= 0[/tex]
[tex]L_{\lambda }= a = b^{b}[/tex]
[tex]L_{\mu }= c = ln (d)[/tex]
This is where I am stuck
I tried for quite some time to solve for the system of equations and I am at a point where i don't know where to go.
The things I got out of them is:
[tex]\lambda[/tex] = -[tex]\mu[/tex] This is from [tex]L_{a}=L_{c}[/tex]
and
[tex]bd=\frac{1}{2}[/tex]
I got this by taking [tex]L_{a}=0[/tex] and [tex]L_{b}=0[/tex] therefore:
[tex]L_{a} = L_{b}[/tex] --> [tex]L_{a} - L_{b} = 0[/tex] --> [tex]L_{a} - L_{b} = L_{c}[/tex]
And so on till I got: [tex]L_{a} - L_{b} - L_{c} - L_{d} = 0[/tex]
Then using some substitution for [tex]\lambda[/tex] and [tex]\mu[/tex] I got bd =[tex]\frac{1}{2}[/tex]
The instructor of my course said I could use software on any of the problems in the handout but even when I tried plugging the equations into mathematica I got an error. I just don't know where to go with the equations.
[itex]L_\lambda = a - b^2[/itex] and [itex]L_\mu= c - ln (d)[/itex] are binding; so a = b^2 and c = ln (d). These plus the 4 equations Lp = 0 for p = a, b, c, d give you 6 equations in 6 unknowns (a, b, c, d, [itex]\lambda, \mu[/itex]).
In mathematica try Solve[eq1 == ... == eq6 == 0}. (Edit: Solve[eq1 == ... == eq6 == 0].)
Thanks for the response
I typed it in as you instructed (as close as possible to yours)
I received the response that is shown in my attachment. Why does it not give me numeric results? I could have received 20 different representations for that if I wanted to simply by rearranging equations.
Can I use these results to get numerical results in mathematica or do I need to sit down and start to rearrange equations again?
(which I am doing anyways)
Thanks again
My guess is that the "Log" term is creating a nonlinearity that Mathematica finds difficult to solve analytically. An alternative solution method:
FindRoot[
D[L[a, b, c, d, \[Lambda], \[Mu]], a] ==
D[L[a, b, c, d, \[Lambda], \[Mu]], b] ==
D[L[a, b, c, d, \[Lambda], \[Mu]], c] ==
D[L[a, b, c, d, \[Lambda], \[Mu]], d] ==
D[L[a, b, c, d, \[Lambda], \[Mu]], \[Lambda]] ==
D[L[a, b, c, d, \[Lambda], \[Mu]], \[Mu]] == 0
{{a, 1}, {b, 1}, {c, 2}, {d, Log[2]}, {\[Lambda], 1}, {\[Mu], 1}}
yields:
{a -> 0.289624, b -> 0.538168, c -> -0.0735622,
d -> 0.929078, \[Lambda] -> 0.726373, \[Mu] -> -0.726373}
You can also try substituting Exp[c] = d for c = Log[d]. The "Exp" expression seems to work with Solve. Defined that way, Solve yields:
which is the identical to the FindRoot solution above.
Are you supposed to use Lagrange multipliers? Perhaps the approach minimizing would be good, too.
Reformulation: Minimize [tex]H(s,t)=(t-s)^2+(t^2-\ln s)^2[/tex] for [tex]s,t \in \mathbb R[/tex] and [tex]s>0[/tex].
Differentiating:
[tex]H_t=2(t-s)+4t(t^2-\ln s)=0[/tex]
[tex]H_s=-2(t-s)-\frac{2(t^2-\ln s)}s=0[/tex]
Adding these two equations yields:
[tex]4t(t^2-\ln s)-\frac{2(t^2-\ln s)}s=0[/tex]
[tex](t^2-\ln s)\left(4t-\frac{2}s\right)=0[/tex]
Using these equations we get [tex]2ts=1[/tex].
By plugging this into one of the above equation we get
[tex]2(t-1/2t)+4t(t^2+\ln(2t))=0[/tex]
One equation, one unknown - perhaps easier to solve.
More generally: Minimize [tex]H(s,t)=(t-s)^2+(f(t)-g(s))^2[/tex].
Differentiating:
[tex]H_t=2(t-s)+2f'(t)(f(t)-g(s))=0[/tex]
[tex]H_s=-2(t-s)-2g'(s)(f(t)-g(s))=0[/tex]
[tex]f'(t)(f(t)-g(s))-g'(s)(f(t)-g(s))=(f'(t)-g'(s))(f(t)-g(s))=0[/tex]
Two possibilities:
[tex]f(t)=g(s)[/tex] which implies (using the above equations) [tex]t=s[/tex], i.e. the two graphs have intersection.
[tex]f'(t)=g'(s)[/tex] (the tangent lines are parallel) and [tex]t-s+f'(t)(f(t)-g(s))=0[/tex] (the line segment between the two points is perpendicular to the tangent line)
This corresponds very nicely to our geometrical intuition.
[I guess this is what your teacher wants you to see - at least that's why there is the last question.]
I tried to simply minimize the equation like you did kompik since I cannot get mathematica to spit out the results (I don't know why, but it doesn't matter).
I couldn't get mathematica to solve the equation so I simply put it into my calculator and used the zero function to get my answer. I got 0.538168 for the s value in your equation.
To find the error in this estimation (since my calculator only gives me the answer to a few decimals)
t = 0.538168
[tex]2(t-1/2t)+4t(t^2+\ln(2t))=3.6947 x 10^{-6}[/tex]
[tex]\frac{0.538168-3.6947 x 10^{-6}}{0.538168} x 100 = 99.9993 Percent[/tex] << Good enough for me. Thanks for the help.
  • · Replies 16 ·
  • · Replies 30 ·
