Helium Balloon and Compton Generator
The discussion focuses on the mechanics of the Compton generator, illustrating the Coriolis force's effect on water movement within a rotating frame. When a toroidal glass tube filled with water is spun 180 degrees, the Coriolis force causes the water to move due to differential forces acting on the northern and southern portions of the tube. The speed of the water post-rotation is calculated as v = 2Rcos[θ], where R is the radius of the ring and θ is the colatitude. This demonstrates the practical application of the Coriolis effect in a classical mechanics context.
  • Understanding of Coriolis force in rotating frames
  • Familiarity with classical mechanics principles
  • Knowledge of angular velocity and its implications
  • Basic mathematical skills for solving physics equations
  • Study the mathematical derivation of the Coriolis force in rotating systems
  • Explore applications of the Coriolis effect in meteorology and oceanography
  • Learn about inertial frames and their significance in physics
  • Investigate the dynamics of fluid motion in rotating systems
Physics students, educators, and anyone interested in classical mechanics and the practical implications of the Coriolis force in fluid dynamics.
Sculptured
From Classical Mechanics by Taylor:
"The Compton generator is a beautiful demonstration of the Coriolis force due to the Earth's rotation,... A narrow glass tube in the shape of a torus or ring (radius R of the ring >> radius of the tube) is filled with water, plus some dust particles to let one see any motion of the water. The ring and water are initially stationary and horizontal, but the ring is then spun through 180 degrees about its east--west diameter. Explain why this should cause the water to move around the tube. Show that the speed of the water just after the 180 degree turn should be 2 [tex]\Omega[/tex] R cos[[tex]\theta[/tex]] . [tex]\Omega[/tex] is the Earth's angular velocity and [tex]\theta[/tex] is the colatitude..."
Alright, so I've figured that in the rotating frame if you make the 180 spin in the direction of the Earth then the southern portion has a force to the west and the northern portion has one to the east. This causes the torque upon the water and its subsequent motion. Now, the only way I can solve the problem is to get out into the inertial frame but I'd like to know how to find the speed using the effect of the colioris force. Any advice on where to begin in this direction?
The Coriolis force is a force that acts on an object moving in a rotating frame of reference, and it can be used to calculate the speed of an object in this frame. To calculate the speed of the water after the 180 degree turn, you need to consider the change in velocity due to the Coriolis force. The Coriolis force is given by F = 2m \Omega \times v, where m is the mass of the water and \Omega is the angular velocity of the Earth. The change in velocity due to the Coriolis force is then given by \Delta v = 2\Omega \times v. Thus, the speed of the water just after the 180 degree turn can be calculated as v= \Delta v/2\Omega = 2Rcos[\theta].
10K
10K
  • · Replies 21 ·
