Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Beyond the Standard Model
Reply
image Elementary Particle Explorer Share It Thread Tools Search this Thread image
Old Aug14-08, 10:08 AM                  #465
garrett
garrett is Offline:
http://deferentialgeometry.org/epe/
Old Aug14-08, 10:18 AM                  #466
MTd2
MTd2 is Offline:
Re: An Exceptionally Technical Discussion of AESToE
Garrett, would mind putting a different representation instead of colors. I am color blind, and sometimes I can't tell apart heads and tails.
Also, what is your "my standard model"?
Old Aug14-08, 11:44 AM                  #467
arivero
arivero's Avatar
arivero is Offline:
Recognitions:
related some grouping of 6 and the projections having sort of hexagonal symmetry in your gadget: I was reading now a series of lectures on Duality Symmetries, by A. Sen in Les Houches in the 2001 session, and for the 4 dimensional duality of SO(32) heterotic, compacted with T^6, some groups of 6 appear:
- a symmetric 6x6 matrix, giving 21 scalars
- an antisymmetric 6x6, giving 15 scalars
- a 6x16 object giving 96 scalars, related to "the gauge fields in the Cartan subalgebra of the gauge group".
Sen refers to his fundational paper hep-th/9402002 for more info. It is a dense paper, but one can search for the number 16 :-)
I can not bet for an interpretation of the 21 and 15. An interesting observation is that if one reduces the standard model to SU(3)xU(1) then both the neutrinos and the top are lost (assume the mass of the top is related to the W and Z), and then the number of degrees of freedom of the fermionic sector is 2*36.
Old Aug14-08, 01:45 PM                  #468
MTd2
MTd2 is Offline:
Sorry, I just noticed that it is the default name for any moviment I can make.
Old Sep9-08, 12:49 PM                  #469
yoyoq
yoyoq is Offline:
so...how was lunch with distler?
what did you guys eat?
who paid?
how much of a tip did you leave?
Old Sep9-08, 01:36 PM                  #470
MTd2
MTd2 is Offline:
Garrett,
Yoyoq,
I posted your question here!!!:
http://golem.ph.utexas.edu/category/...n.html#c018769
Old Nov26-08, 08:18 PM                  #471
rntsai
rntsai is Offline:
a year later...any progress on finding a way to fit three generations into e8?
Old Jan1-09, 04:57 PM       Last edited by Berlin; Jan2-09 at 02:58 AM..            #472
Berlin
Berlin is Offline:
Maybe the best strategy for E8 fans would be to accept the fact that only one generation fits into the full E8! That is, I think, not as strange as it looks. In fact, the three generations are only distinguishable in mass (and could so, be identical in the mass to zero limit). Having three doublets of Higgs could cause three different mass levels only after breakdown of some of the E8 symmetries. See it like the only true generation is stuck in three different potential wells (maybe even combined with a Pauli principle). I am trying to use a kind of trinification model based on SU(2)^3, breaking down to three left SU(2)xSU(2)xU(1) groups with a left-right symmetry breaking a la Senjanovic. One of these left SU(2) groups should be part of gravity, the rest is EW. Only the 128 spinor "1/2" states of E8 seems to be required for the fermions. Whether this means that even gravity only exists in its current form after a symmetry breaking I do not know (or that the very notion of left-right comes along at that moment). All crazy ideas and the maths turns out too difficult for me anyway. Fun though.
berlin
Old Jan20-09, 04:05 PM                  #473
CarlB
CarlB's Avatar
CarlB is Offline:
Recognitions:
Homework Helper Homework Helper
On the generation structure, Marni Sheppeard and I have been working on a method of describing it based on (my view of things may differ from hers) the discrete Fourier transform. Partly to justify this, I've applied the same theory to the hadrons and have found 39 equations relating their masses.
This is similar to Regge trajectories (which were used as the basis for string theory). Regge trajectories are equations that relate the masses of the same hadrons but with different angular momenta. The equations I've got relate the same hadrons but with different radial excitations. But it attributes the different radial excitations to color phase effects.
I'm submitting this to Phys Math Central next week and would appreciate comments on it:
http://www.brannenworks.com/koidehadrons.pdf
As far as E8 theory goes, this would mean something like E8 x discrete Fourier transform for the generations.
Old Jan20-09, 07:29 PM       Last edited by MTd2; Jan20-09 at 08:21 PM..            #474
MTd2
MTd2 is Offline:
Hi Carl,
Have you contacted Garrett Lisi about this? He could surely help you. Also, he colaborated intesively with Lee Smolin. I would like to know what you would talk to them, if you are willing to. You should also ask Tommaso Dorigo.
Old Jan20-09, 08:21 PM                  #475
MTd2
MTd2 is Offline:
Another question,
I really really expected to see the top mass calculated with you method... I know, everything else is really awesome, but I am disapointed with this one...
Old Jan23-09, 09:23 PM                  #476
CarlB
CarlB's Avatar
CarlB is Offline:
Recognitions:
Another example of a cute theory that only gives one generation of the elementary fermions, see:
Symmetries of Nonrelativistic Phase Space and the Structure of Quark-Lepton Generation
Piotr Zenczykowski.
According to the Hamiltonian formalism, nonrelativistic phase space may be considered as an arena of physics, with momentum and position treated as independent variables. Invariance of x^2+p^2 constitutes then a natural generalization of ordinary rotational invariance. We consider Dirac-like linearization of this form, with position and momentum satisfying standard commutation relations. This leads to the identification of a quantum-level structure from which some phase space properties might emerge. Genuine rotations and reflections in phase space are tied to the existence of new quantum numbers, unrelated to ordinary 3D space. Their properties allow their identification with the internal quantum numbers characterising the structure of a single quark-lepton generation in the Standard Model. In particular, the algebraic structure of the Harari-Shupe preon model of fundamental particles is reproduced exactly and without invoking any subparticles. Analysis of the Clifford algebra of nonrelativistic phase space singles out an element which might be associated with the concept of lepton mass. This element is transformed into a corresponding element for a single coloured quark, leading to a generalization of the concept of mass and a different starting point for the discussion of quark unobservability.
http://arxiv.org/abs/0901.2896
So does the above have anything to do with the way Garrett packs a single generation into E8? I don't think so but others understand his theory better than me.
P.S.
MTd2, when I had done this originally, it was based on assumptions which violated special relativity. That probably put Smolin off his feed. The latest version hides all that stuff by sticking to quantum information theory (where position and momentum are ignored, hence there is no need for special relativity or a replacement for it) and so that might get by better.
I seem to have given it an attractive abstract because some important people have written to me saying that they are very busy, especially this time of year, but they are going to take the time to read the paper. I think that basically, it's an attractive way of extending Regge trajectories to radial excitations and I wonder if I should give it a title that mentions Regge trajectories instead of Koide mass formulas. Hmmm.
Old Jan25-09, 04:25 PM                  #477
rntsai
rntsai is Offline:
I quickly read through this and I'm afraid I don't
see the main point. It looks like you take these
masses three at a time and find a data fit for them
using three real parameters. You use 3x3 circulant
matrices to inspire the form of this fit. These matrices
(and their eigenvalues) are defined by 3 parameters.
It's well known that all circulant matrices (any size)
are diagonalized by the discrete fourier transform matrix,
so they will all have the same eigenvectors; I don't think
that adds anything. At the end, it's still just a fit of 3
numbers by three parameters. It doesn't look like there's any
relation between the different fits...each has it's own
set of 3 parameters (right?). It's also not apparent how
special these fits are. It seems there are enough degrees
of freedom to fit any randomly picked 3 numbers to this
form...
Old Jan26-09, 04:01 PM                  #478
CarlB
CarlB's Avatar
CarlB is Offline:
Recognitions:
Originally Posted by rntsai View Post
I quickly read through this ...
At the end, it's still just a fit of 3 numbers by three
parameters.
Thanks for reading! You are right that this is the effect of the discrete Fourier transform; it takes three real variables and turns them into three real variables (or one real variable and one complex variable). Whichever, it keeps 3 real degrees of freedom. But read on.
It doesn't look like there's any relation between the different fits. Each has it's own set of 3 parameters (right?).
No, there are only two parameters for each fit, "s" and "v". You're probably confused by the LaTeX Code: \\mu_e constant that is in front of each fit. This is a constant equal to 25.054 square root MeV and is not a parameter. It's value never changes. It's taken from the electron fit.
If it still isn't obvious that there are only two degrees of freedom, note that LaTeX Code: \\mu_e multiplies s and v. So you could define
LaTeX Code: s_e = \\mu_e s, \\;\\;v_e = \\mu_e v
and get each fit down to two real parameters.
By the way, you're not the only one to make this error. When my neutrino paper came out a few years ago it used similar notation and I had a professor of physics tell me that it used 4 parameters, LOL. It must be a natural mistake on a fast read. I've got the LaTeX Code: \\mu_e factored out because it's a natural scale.
By the way, if I had 3 real parameters to play around with, I wouldn't have errors, LOL. The third parameter becomes the angle delta. The claim is that the mass spectrum can be closely approximated by quantizing delta as LaTeX Code: 2/9 or LaTeX Code: 2/9 + \\pi/12
I wouldn't be surprised if other people make the same error, but I don't think I'm going to eliminate the scale factor. From a sociological point of view, a paper that has not passed peer review gets read by people who don't expect anything good and really don't pay very close attention to the details. So they reject things as soon as they find the first detail that disagrees with them. But after a paper is past peer review this effect should go away.
Old Mar12-09, 09:51 PM                  #479
MTd2
MTd2 is Offline:
Garrett has some new ideas. Jacques Distler couter argues:
http://golem.ph.utexas.edu/category/...t.html#c022012
Old May9-09, 01:50 PM                  #480
arivero
arivero's Avatar
arivero is Offline:
Recognitions:
http://www.slac.stanford.edu/spires/...RXIV:0711.0770
image image
Reply
Thread Tools
Similar Threads for: An Exceptionally Technical Discussion of AESToE
Thread Thread Starter Forum Replies Last Post
An Exceptionally Simple Theory of Everything! marcus Beyond the Standard Model 207 Feb7-10 10:55 AM
Wearing Clothing in Exceptionally Hot Weather? Simfish General Discussion 20 Jul19-08 08:23 AM
Regarding Lisi's AESToE Ivan Seeking General Discussion 4 Dec13-07 04:30 PM
No comments on "An Exceptionally Simple Theory of Everything" ? Toon Moene General Physics 0 Nov16-07 05:01 AM
I am wondering if I am exceptionally visual physicscrap Medical Sciences 22 Oct23-07 12:33 AM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2010 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
