Calculating the Sum of a series
  • Thread starter Thread starter Saladsamurai
    Series Sum
The discussion revolves around calculating the sum of an infinite series involving a geometric series and harmonic series components. The original poster presents a series and attempts to manipulate it using partial fractions and distribution of summation.
  • Mixed
  • The original poster attempts to separate the series into distinct components and questions the validity of distributing the summation across terms. They express confusion over the divergence of the harmonic series and its implications for the overall sum.
Participants are actively engaging with the original poster's reasoning. Some have pointed out that the last two series do not completely cancel, suggesting that a closer examination of the terms is necessary. There is an exploration of the relationship between the divergent series and their difference, which may yield a finite result.
There is a mention of a specific example from the original poster's text that leads to a finite answer, raising questions about the conditions under which the series can be manipulated. The discussion includes considerations of index adjustments and the importance of correctly identifying terms in the geometric series formula.
Saladsamurai
[tex]\sum_{k=1}^{\infty}(\frac{1}{5^k}-\frac{1}{k(k+1)})[/tex]
Now by partial fractions and distributing the sum across all three terms I get
[tex]\sum_{k=1}^{\infty}\frac{1}{5^k}-\sum_{k=1}^{\infty}\frac{1}{k}+\sum_{k=1}^{\infty}\frac{1}{k+1}[/tex]
Then I am going with: 1st is geometric; 2nd is Harmonic; and 3rd is similar to Harmonic So, 2nd and 3rd diverge.
So the sum should equal [tex]\frac{a}{1-r}[/tex].
But this the not match the text answer, what am I doing wrong?
Thanks,
Casey
EDIT: I noticed an example in my text in which I use (1/k)-1/(k+1) to write the closed form and get a finite answer of 1.
Why is this the case if I can distribute the sigma across the terms.
Your last two series do not completely cancel; write out the first few terms of each to see.
I can see now that [tex]-\frac{1}{k(k+1)})[/tex] goes to 1, but why does distributing change things? Or am I doing something wrong here?
Casey
Casey
It's not a question of how things are distributed: it's that the two harmonic series are just one term out of step with each other. So the individual series are divergent, but their difference is finite (a classic case of an indeterminate difference yielding a finite non-zero value).
The difference
[tex]-\sum_{k=1}^{\infty}\frac{1}{k}+\sum_{k=1}^{\infty} \frac{1}{k+1}[/tex]
is really like writing
[tex]-\sum_{k=1}^{\infty}\frac{1}{k}+\sum_{k=2}^{\infty} \frac{1}{k}[/tex] ,
so all the terms except the first one in the first sum cancel exactly...
[EDIT: Sorry, moved that index the wrong way before...]
Ah, also beware: the value for a in the geometric series is not 1 (maybe you already caught that, but a frequent mistake made in using the formula for an infinite geometric series is not observing the index for the first term).
  • · Replies 17 ·
