Static Equilibrium in Fluids: Pressure and Depth
The problem involves a cylindrical container filled with mercury and water, where the total pressure at the bottom is given. Participants are exploring how to determine the depth of mercury based on the pressure conditions described.
  • The original poster attempts to apply the pressure formula relating atmospheric pressure, density, gravity, and height. Some participants question the setup and suggest corrections to the pressure equation, emphasizing the contributions from both fluids.
Participants are actively discussing the problem, with some providing hints and corrections to the original poster's approach. There is a focus on clarifying the relationships between the pressures due to the different fluids and how to set up the equations correctly.
There is an indication that the problem may involve assumptions about atmospheric pressure, which some participants suggest should be clarified based on the problem statement.
smichels
A cylindrical container 1.2 m tall contains mercury to a certain depth, d. The rest of the cylinder is filled with water. If the pressure at the bottom of the cylinder is 1.9 atm, what is the depth d?
Does anyone have any ideas on how to approach this problem, better yet,solve it!?
We are not here to solve problems, until you show us that you have tried your best and shown us the attempts. Then we'll guide you as best as we can.
Hint: Potential Energy
Sure, I understand. Here is what I have done so far:
The pressure at the bottom of a cylinder is equal to the force at the bottom divided by the Area, or
[P(bottom) = P(atmosphere) + density*gravity*height.
because we are dealing with water and mercury, do I need to equate this formula to:
P(at) + dens(water)*gravity*Height(cylinder)=P(at)+dens(mercury)*gravity*height(x). Where we solve for the height (x)
Am I on the right track?..
Some corrections.
P at bottom = P_atm + P(due to mercury) + P(due to water)
= P_atm + dens(mercury)*(height of mercury)*g + dens(water)*(height of water)*g.
Now you can put h of Hg as d and h of water as 1.2-d, ans solve. (Whether you have to neglect atm pressure depends on whether that has been mentioned in the problem.)
  • · Replies 27 ·
10K
