Completely Inelastic Collision: A block and a block with a spring
The discussion centers on a completely inelastic collision involving two blocks, where block m1 (2.0 kg) moves at 10 m/s and block m2 (5.0 kg) moves at 3.0 m/s, with a spring (k=1120 N/m) attached to m2. The maximum compression of the spring is calculated using conservation of momentum and energy principles. The correct final velocity after the collision is determined to be 5 m/s, leading to a maximum spring compression of 0.37 m. The user struggled with calculating the initial and final kinetic energies, which are crucial for determining the energy transferred to the spring.
  • Understanding of completely inelastic collisions
  • Familiarity with conservation of momentum
  • Knowledge of kinetic energy calculations
  • Basic principles of spring mechanics (Hooke's Law)
  • Study the principles of conservation of momentum in inelastic collisions
  • Learn how to calculate kinetic energy before and after collisions
  • Explore the relationship between kinetic energy and spring potential energy
  • Investigate more complex collision scenarios involving multiple bodies and springs
Students in physics, particularly those studying mechanics and dynamics, as well as educators seeking to clarify concepts related to collisions and energy transfer in systems involving springs.
brendan3eb
I actually have two problems that I have been struggling with that are very similar, so I believe that I am making the same incorrect assumption for both problems, but I am at that point where I have been re-trying the problems for so long that I do not think I am going to find my mistake.
A block of mass m1=2.0 kg slides along a frictionless table with a speed of 10 m/s. Directly in front of it, and moving in the same direction, is a block of mass m2=5.0 kg moving at 3.0 m/s. A massless spring with spring constant k=1120 N/m is attached to the near side of m2, as shown in Fig. 10-35. When the blocks collide, what is the maximum compression of the spring? (Hint: At the moment of maximum compression of the spring, the two blocks move as one. Find the velocity by noting that the collision is completely inelastic at this point.)
m1v1i+m2v2i=(m1+m2)v
K2-K1=W
W=(1/2)kx^2
m1=2.0 kg
v1i=10 m/s
m2=5.0 kg
v2i=3 m/s
k=1120 N/m
Pi=Mv
m1v1i+m2v2i=(m1+m2)v1
v1=(m1v1i+m2v2i)/(m1+m2)
v1=(2*10+5*3)/(2+5)=5 m/s
K2-K1=W
(1/2)m1(v1)^2-(1/2)m1(v1i)^2=-(1/2)kx^2
(1/2)s cancel out
(2)(5)^2-(2)(10)^2=-(1120)(x)^2
x^2=.134
x=.37 m
It looks as though all the units cancel out right and I do not have to convert any the units.
re-tried it a few more times to no avail
Your problem is with computing the energies.
Before the collision, what is the total kinetic energy of the two blocks?
After the collisiion, what is the total kinetic energy of the two blocks?
The difference equals (1/2)kx^2, but both your initial and final KE's are wrong.
