Quick help in Geometric series question
The convergence of the geometric series defined by the common ratio \( r = \frac{5x}{4+x^2} \) requires that \( |r| < 1 \). This leads to the inequalities \( -1 < \frac{5x}{4+x^2} < 1 \). The correct solution for the values of \( x \) that satisfy these conditions is \( \{x: -1 < x < 1\} \cup \{x: x < -4\} \cup \{x: x > 4\} \). The initial incorrect interpretation mistakenly included all reals, which does not satisfy the convergence criteria.
  • Understanding of geometric series and convergence criteria
  • Knowledge of inequalities and their manipulation
  • Familiarity with rational functions and their behavior
  • Ability to solve polynomial inequalities
  • Study the properties of geometric series and their convergence conditions
  • Learn how to solve rational inequalities effectively
  • Explore polynomial functions and their roots
  • Investigate the implications of convergence in series for real analysis
Students studying calculus, particularly those focusing on series convergence, as well as educators and tutors assisting with geometric series problems.
rock.freak667
The common ratio,ratio,r, of a geometric series is given by:
[tex]r=\frac{5x}{4+x^2}[/tex]
Find all the values of x for which the series converges
For the series to converge |r|<1
so that
[tex]|\frac{5x}{4+x^2}|<1[/tex]
this means that:
[tex]-1<\frac{5x}{4+x^2}<1[/tex]
For
[tex]-1<\frac{5x}{4+x^2}[/tex]
I get
{x:x<-4}U{x:x>-1}
and for
[tex]\frac{5x}{4+x^2}<1[/tex]
I get
{x:x<1}U{x:x>-1}
The answer I want would be the region that satisfies both {x:x<1}U{x:x>-1} AND {x:x<-4}U{x:x>-1} right?
So I get
{x:x<1}U{x:x>-1} which is basically {x:-1<x<1}...(*answer I got)
is that correct? because I see that the answer is {x:-1<x<1}U{x:x<-4}U{x:x>4}
I am not sure if that is the same as what I have because I think that the answer I got includes the rest of {x:x<-4}U{x:x>4}
no. You are incorrect.
The answer you got includes all reals: x > -1 in union with x < 1 includes all numbers less than one and greater than -1 or all reals. And all reals is not correct (take 3 as a counter example).
The answer in the book is correct: {x:-1<x<1}U{x:x<-4}U{x:x>4}
rock.freak667 said:
For
I get
{x:x<-4}U{x:x>-1}
I'm finding in this case (x+1)(x+4) > 0 , so either
x>-1 and x>-4 implies x>-1
or
x<-1 and x<-4 implies x<-4
So we are in agreement here.
and for
I get
{x:x<1}U{x:x>-1}
In this case, I find (x-1)(x-4) > 0 , so either
x>1 and x>4 implies x>4
or
x<1 and x<4 implies x<1
Perhaps you "miswrote" yourself here?
Combining the two cases gives
x < -4 , -1 < x < 1 , x > 4 .
As a check, you'll find that values of x with absolute value between 1 and 4 don't work in the original inequality.
