Line Integral Problem: Evaluating F(x,y) on Lower Half of Unit Circle
The line integral of the vector field F = x²i + 2xyj over the lower half of the unit circle cannot be evaluated using the Fundamental Theorem of Line Integrals because F is not an exact differential. Specifically, the mixed partial derivatives (∂(x²)/∂y and ∂(2xy)/∂x) are not equal, confirming that no potential function f(x,y) exists such that F = ∇f. The correct approach involves parameterizing the curve using r(t) = for -π ≤ t ≤ 0 and directly integrating the expression derived from substituting dx and dy into the integral.
  • Understanding of vector fields and line integrals
  • Familiarity with the Fundamental Theorem of Line Integrals
  • Knowledge of parameterization of curves in calculus
  • Ability to compute derivatives and integrals of functions
  • Study the properties of exact differentials in vector calculus
  • Learn how to parameterize curves for line integrals
  • Practice integrating vector fields over various paths
  • Explore the implications of conservative fields and potential functions
Students studying vector calculus, mathematicians working with line integrals, and educators teaching the Fundamental Theorem of Line Integrals.
Mr Noblet
Let F=x[tex]^{2}[/tex]i+2xyj, and let C be the lower half of the unit circle, with perametrization r(t)=<cos(t),sin(t)>,[tex]\pi[/tex][tex]\leq[/tex]t[tex]\leq[/tex][tex]\pi[/tex]. Evaluate [tex]\oint[/tex]F[tex]\cdot[/tex]dr.
The first thing I tried to do was to find a function f(x,y) so that F=[tex]\nabla[/tex]f
In order to do this I integrated the i portion of F with respect to x which gave me f(x,y)=[tex]\frac{1}{3}[/tex]x[tex]^{3}[/tex]+g(y).
Then to find out what g was I took the derivative with respect to y which just left me with g'(y). I could not think of how to get past this part. I tried doing it with the j first as well in which I first take the integral of the j part of F with respect to y and then the derivative with respect to x. This left me with f[tex]_{x}[/tex](x,y)=y[tex]^{2}[/tex]+f'(x).
Basically I was trying to use the Fundamental Theorem of Line Integrals but I could not find a function f(x,y) so that F=[tex]\nabla[/tex]f. Help would be appreciated.
It's not necessarily the case that F is the gradient of anything. If if happens to be, then the line integral is independent of the path, which makes it particularly easy; but if not, then you just have to do the integral.
Do you mean [itex]-\pi\le x\le 0[/itex]? Or [itex]\pi\le x\le 2\pi[/itex] which would work just as well.
Basically I was trying to use the Fundamental Theorem of Line Integrals but I could not find a function f(x,y) so that F=[tex]\nabla[/tex]f. Help would be appreciated.[/QUOTE]
You can't find such an f because [itex]x^2 dx+ 2xy dy[/itex] is not an exact differential: [itex](x^2)_y= 0[/itex] while [itex](2xy)_x[/itex]= 2y. Since those are not the same, there is no F such that grad F= [itex]x^2\vec{i}+ 2xy\vec{j}[/itex]
With x= cos(t) and y= sin(t), dx= -sin(t)dt and dy= cos(t)dt [itex]x^2 dx+ 2xy dy= cos^2(t)(-sint dt)+ 2cos(t)sin(t)(cos(t) dt)= cos^2(t) sin(t) dt. It should be easy to integrate that directly.[/itex]
