Doppler effect and Ultrasound waves
The discussion centers on calculating the expected beat frequency of ultrasound waves emitted at 450 kHz when measuring blood flow speeds of 3.0 cm/s in large leg arteries. The correct formula for the Doppler Effect is confirmed as F2 = F1 / (1 + (Vs / V)), where Vs is the speed of the moving blood and V is the speed of sound in human tissue, taken to be 1540 m/s. The calculated beat frequency is approximately 81970.26 Hz, demonstrating the application of the Doppler Effect in medical ultrasound technology.
  • Understanding of the Doppler Effect in wave physics
  • Familiarity with ultrasound technology and its applications
  • Basic knowledge of frequency calculations
  • Proficiency in using formulas for sound waves in different mediums
  • Study the derivation of the Doppler Effect formula in detail
  • Learn about the applications of ultrasound in medical diagnostics
  • Explore the effects of varying blood flow speeds on ultrasound measurements
  • Investigate the relationship between frequency and wavelength in sound waves
Students studying physics, medical professionals utilizing ultrasound technology, and anyone interested in the practical applications of the Doppler Effect in healthcare.
mathcrzy
Ultrasound waves are used to measure blood-flow speeds. Suppose a device emits sound at 450 kHz, and the speed of sound in human tissue is taken to be 1540 m/s. What is the expected beat frequency if blood is flowing normally in large leg arteries at 3.0 cm/s directly away from the sound source?
_____Hz
F2 = F1 / ( 1 + ( Vs / V ) )
F2 = 450000 / (1 + ( 1540 / 343 ) )
F2 = 81970.26 Hz
Your formula is wrongIt should be F2 = F1/[1 + v/vs] and what is 343?
I am a bit confused. The OP has used the correct formula for the Doppler Effect for moving source. However, the formula given by you is the correct formula for the beat frequency.
To help the OP, I'll just give a short deduction.
f1 = f/(1 + vs/v) = fv/(v+vs), where v = speed of sound = 1540 m/s, f = 450 kHz, vs = 0.03 m/s.
Frequency of beats = f –f1 = f(1 – v/(v+vs) = f*vs/(v+vs) ~ f*vs/v, since v>>vs.
Now plug in the values.
