Lagrange Multipliers for Volume
The discussion focuses on optimizing the dimensions of a shelter using Lagrange Multipliers under the constraint of 384 square feet of wood. The correct dimensions for maximum volume are established as 16 feet in length and 8 feet in both width and height. The participant initially struggled with formulating the correct constraint equations, mistakenly using volume instead of area. The correct approach involves maximizing the function f(x) = xyz with the constraint λ(384 - 2yz - xz - xy).
  • Understanding of Lagrange Multipliers
  • Familiarity with optimization problems in calculus
  • Knowledge of constraint equations
  • Basic geometry related to volume and surface area
  • Study the method of Lagrange Multipliers in depth
  • Practice formulating constraints for optimization problems
  • Explore geometric interpretations of volume and surface area
  • Review examples of maximizing functions with multiple variables
Students studying calculus, particularly those focusing on optimization techniques, as well as educators seeking to clarify the application of Lagrange Multipliers in real-world scenarios.
stardusto12
The Park Service is building shelters for hikers along the Appalachian Trail. Each shelter has a back, a top, and two sides. Find the dimensions that will maximize the volume while using 384 square feet of wood.
They want me to find the length, width, and height.
Here's my problem, I can't form a constraint for the problem because I don't know what they are looking for. The constraints I formed (two of them) did not work (they are below along with the formula I used).
F(x)=2zy+xz+xy
constraint used= Lambda(384-xyz)
and
f(x)=xyz
constraint used= lambda(384-2yz-xz-zy)
The answers I got are WAY off the correct answers. The correct answers are 16 (length) and 8 (for both width and height).
Can someone please tell me if I used the wrong equations, and if I did, how to form an equation from the given problem. I know how to calculate the answers, just not how to form the equation from a word problem. Thank you.
The second form is correct. Extremize xyz-lamba(384-2yz-xz-xy) (note the typo in the what you have shown - xy turned into zy). The constraint is on area, not volume.
By the way, the Park Service does not build shelters along the Appalachian trail. They are built entirely by volunteers, members of the Appalachian Trail Conservancy and its affiliates.
  • · Replies 16 ·
