Can Acidic Liquids Corrode a 3 Inch Iron Stick?
  • Thread starter Thread starter Jekertee
    Iron
The discussion revolves around the effects of acidic liquids, specifically sulfuric acid, on a 3-inch iron stick. Participants explore the potential for corrosion and the observable changes that might indicate wear on the iron stick.
  • One participant questions what is meant by "worn" in the context of the iron stick being placed in sulfuric acid.
  • Another participant suggests that the stick would change color in sulfuric acid, indicating chemical reactions, and mentions the production of hydrogen gas as a sign of corrosion.
  • A participant expresses confusion regarding the term "baz jar," indicating a lack of clarity in the original question.
  • There is a humorous exchange about the absurdity of the question and the terminology used, with references to coding examples.
  • One participant jokingly suggests considering other metals like gold or platinum instead of iron for the experiment.
  • Another participant shares a negative impression of the color changes observed during similar experiments, implying a distaste for the results.
Participants do not reach a consensus on the clarity of the original question or the implications of the experiment. There are multiple interpretations of the term "worn" and the meaning of "baz jar," leading to confusion and humor rather than a focused technical discussion.
The discussion lacks clear definitions for terms used, such as "baz jar," and does not resolve the ambiguity surrounding the concept of wear in the context of chemical reactions with iron.
Jekertee
Ok, this is from the first's: :wink:
I have an iron stick of 3 inch long,
If I insert this stick into a baz jar then immediately insert it into an acidic (H2SO4 liq)
will that stick be worn out ?
How do I know it is worn ?
Thanks
Joan John
Chemistry news on Phys.org
What do you mean by worn?
The stick should change color in sulfuric acid. Iron (2) sulfate is green. Iron (3) sulfate is yellow. It would also create hydrogen gas, so the acidic solution would start bubbling.
You lost me at 'baz jar'...
It's the opposite of foobar? :smile:
These kinds of questions are killer. The expert and the questioner have no idea what either one is saying. Next, the questioner gets angry because the expert cannot figure out what s/he really means. You should see the questions on Evolution. Even some of the well educated people go off the chart once in a while.
* foo bar and baz are "standard names" for dummy functions in C coding examples.
Thanks
Joan John
Do you really want to do it with iron, or with Gold, Platinum, Rhodium, ecc. maybe? :wink:
ShawnD said:
Putting gold in a baz jar? You're a maniac! :eek:
Then I haven't grasped very well the term "baz jar". What does it mean?
Well if it is possible go for it.:biggrin:
The color looks seriously disgusting, I have watched it, I would not dare to report my projectmate's experiments with insertions of an iron stick into different jars on board for you to have a clearer analyses.
  • · Replies 19 ·
11K
  • · Replies 17 ·
10K
