Register to reply
Moment of inertia of a hollow sphere
by chickendude
Tags: hollow, inertia, moment, sphere
Share this thread:
chickendude
#1
Dec17-07, 04:53 PM
P: 28
Find the moment of inertia of a hollow sphere with mass m and radius R and uniform density
2. Relevant equations
Since the hollow sphere is an area, the density is mass divided by area, so:
[tex]I = \int r^2 dm = \frac{m}{A}\int r^2 dA[/tex]
3. The attempt at a solution
. The total area is 4pi r^2, so here is what I got
[tex]dA = 2\pi \sqrt{R^2-r^2}dr[/tex]
[tex]I = \frac{m}{4\pi R^2} \int_{-R}^{R} r^2(2\pi\sqrt{R^2-r^2})dr[/tex]
[tex]I = \frac{m}{R^2} \int_{0}^{R} r^2\sqrt{R^2-r^2}dr[/tex]
From here I made the substitution [tex]r = R\sin{\theta}[/tex] and got
[tex]I = mR^2 \int_{0}^{\frac{\pi}{2}} \sin^2\theta\cos^2\theta d\theta[/tex]
And that evaluated to pi/16, which brings me to my problem
the correct answer is supposed to be [tex]I = \frac{2mR^2}{5}[/tex]
Phys.Org News Partner Science news on Phys.org
'Office life' of bacteria may be their weak spot
Lunar explorers will walk at higher speeds than thought
Philips introduces BlueTouch, PulseRelief control for pain relief
what
#2
Dec17-07, 06:10 PM
P: 91
Is it a hollow sphere(a spherical shell) or a solid sphere? Because the answer that you say is supposed to be correct is for a solid sphere, unless I've made some error. They're both pretty similar and I think you're going to get into trouble if you don't use curvilinear coordinates, at least it was much easier for me to do it that way. My response is to a spherical shell which will not give the answer you say is correct. However, a solid sphere can be done in a similar way and does give the answer you say is correct.
First, something to notice is that in spherical coordinates a volume element is [tex] R^2 \sin (\theta) d\theta d\phi dR[/tex]. For a spherical shell R is constant and the volume element becomes an area element [tex] dA= R^2 \sin (\theta) d\theta d\phi [/tex]. Can you now do the integral keeping in mind that in your initial given equation r is the perpendicular distance from an axis passing through the center of mass? (I assumed it was moment of inertia wrt the center of mass)
chickendude
#3
Dec17-07, 06:33 PM
P: 28
You are right. I am sorry. I looked up the wrong answer in the chart.
It should be [tex]\frac{2mR^2}{3}[/tex]
I will look into the spherical coordinate method
Yes, it worked. The error was my r was not actually representing the perpendicular distance.
Here is what I did:
[tex]\frac{m}{A}\int r^2 dA[/tex]
[tex]A = 4\pi R^2[/tex]
[tex]r = R\sin\phi[/tex] (simple spherical geometry)
[tex]dA = 2\pi r dz = 2\pi * R\sin\phi * R d\phi[/tex] (definition of radian and the statement above)
[tex]dA = 2\pi R^2 \sin\phi d\phi[/tex]
plugging in
[tex]\frac{m}{4\pi R^2} \int_{0}^{\pi} R^2\sin^2\phi * 2\pi R^2 \sin\phi d\phi[/tex]
[tex]\frac{mR^2}{2} \int_{0}^{\pi}\sin^3\phi d\phi[/tex]
That integral evaluates to 4/3, and bam, it works
Thanks a lot
phoenix39
#4
Nov22-09, 12:09 AM
P: 2
Quote Quote by chickendude View Post
Thanks a lot
How would you get 4/3 for the intergral, i used substitution rule and always got 2/3 for the answer.
∫_0^π▒〖sin〗^3 ϕ dϕ=∫_0^π▒〖(1-〖cos〗^2 ϕ)〗sinϕ dϕ
u= cosϕ du=-sinϕ dϕ
so ∫_1^0▒〖-(1-u^2 )du〗=∫_0^1▒〖1-u^2 du〗 = 2/3
what is my problem?
ideasrule
#5
Nov22-09, 01:14 AM
HW Helper
ideasrule's Avatar
P: 2,322
You didn't convert the bounds of integration correctly. cos(pi)=-1, not 0.
phoenix39
#6
Nov22-09, 01:21 AM
P: 2
Thanks alot....why I am so stupid....-_-llll
tejas
#7
Jan3-11, 10:24 AM
P: 7
HI, I understand everything, except that in the solution, dz is written as R d\phi. why is that? shouldnt it be Rsin(phi)d(phi) or even, if we take x = R*cos(phi) (from that same simple geometry) than dz would be -Rsin(phi)d(phi)
Register to reply
Related Discussions
Moment of inertia of a hollow sphere Introductory Physics Homework 14
What's Wrong with My Line of Reasoning? Calculating a Hollow Sphere's Moment Inertia Calculus 8
Moment of inertia of a sphere Introductory Physics Homework 8
Rotational Inertia of a hollow sphere(having trouble!) Introductory Physics Homework 6
