| Thread Closed |
heat exchangers |
Share Thread |
| Dec18-07, 08:05 AM | #1 |
heat exchangers
can anyone explain me the
1>significance 2>elements used to construct them 3>main usage to which industries of heat exchangers?????????????? |
| Dec18-07, 08:21 AM | #2 |
Admin
One can google on "heat exchangers". Is this a homework problem?
The main purpose of a heat exchanger (HX) is to "exchange heat", most commonly from one working fluid to another, while maintaining separation of the two fluids, which could be the same fluid, but under very different thermophysical conditions, or two distinctly (chemically) different fluids. The principal elements of the HX are the shell (vessel) containing one fluid, the tubes which contain and transport the other fluid, and support structures (including baffles). Any industry that uses heat will like have some kind of heat exchanger(s) involved in whatever process uses the heat. |
| Thread Closed |
Similar discussions for: heat exchangers
| Heat Engine with Finite Heat Capacity- Is my answer correct? | Introductory Physics Homework | 3 | ||
| [SOLVED] Quantity of Heat/Specific Heat Water+Iron | Introductory Physics Homework | 3 | ||
| Specific Heat and Phase Change/Latent Heat Problems PLEASE HELP | Introductory Physics Homework | 5 | ||
| Imbalance heat transfer in the combined feed exchangers | Mechanical Engineering | 0 | ||
| specific heat capacity and latent heat of fusion | Introductory Physics Homework | 4 | ||
