Thread Closed
Nerd sniping
Share Thread Thread Tools
Dec26-07, 08:37 PM   #1
D H
Mentor
Nerd sniping
From xkcd.com :
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Dec26-07, 09:36 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Is it 0.916333... ohms?
Damn, I missed dinner!
Dec27-07, 06:38 AM   #3
Recognitions:
Homework Helper Homework Help
Quote by Gokul43201 View Post
How did you get that? I think that to solve such problems (where a simple superposition doesn't give you the answer), a discrete fourier transform is required, and then the final integral which gives the resistance looks very tricky.
Dec27-07, 07:12 AM   #4
Nerd sniping
D H: 4 points (or is it 2 and 1, for the engineer? )
Dec27-07, 09:45 AM   #5
D H
Mentor
At least three points, since I made Gokul miss dinner.
This arXiv article (see appendix A) gives an absolute mess. Mathworld (http://mathworld.wolfram.com/news/2004-10-13/google, question 10) uses a different expression and that enables Mathematica to yield [itex](8-\pi)/(2\pi)\approx0.773[/itex] ohms.
Dec27-07, 10:12 AM   #6
Recognitions:
Quote by D H View Post
The article uses the same principle of taking the fourier transform and applying ohm's law. The integral one gets after the fourier transform is (eqn 25 in the article)
[tex] \frac{1}{4 \pi^2} \int_{-\pi}^{\pi} \int_{-\pi}^{\pi} \left( \frac{1-\cos(2x+y)}{2-\cos{x} - \cos{y}} \right) dx dy [/tex].
I'm at home and don't have access to an integrator. Does anyone have access to a math package that evaluates this integral, or a way to find the value? Does it come out as [itex](8-\pi)/(2\pi)\approx0.773[/itex]?
Mathworld seems to have used some substitution in its expression.
EDIT: Nevermind. They've apparently used a contour integral and then a substitution. It's there in appendix A, which I missed the first time.
Dec27-07, 10:29 AM   #7
D H
Mentor
The difference between a normal person and a scientist:
Dec27-07, 10:32 AM   #8
Evo
Mentor
Dec27-07, 10:37 AM   #9
That's actually a normal person and Homer Simpson => Homer = Scientist??
Dec27-07, 12:01 PM   #10
Recognitions:
Quote by siddharth View Post
I actually did use a superposition - I don't know why it fails! =(
I haven't yet looked at the article posted by D H.
Dec27-07, 01:03 PM   #11
It's funny how this thread turned into a discussion about the problem in the comic strip rather than the humour about it.
Dec27-07, 01:08 PM   #12
Recognitions:
Quote by Oerg View Post
It just proves the first sketch of the comic strip. Nerd sniping in action.
Dec28-07, 09:09 PM   #13
Recognitions:
From xkcd.com :
A friend of mine finished school some years ago with a BS in physics and immediately chucked it all to become a lawyer. After seeing this Nerd Sniping XKCD strip I sent it to him on a workday to see if he was truly a lawyer or if he would be sniped, along with with full disclosure of my intentions. Couple days later I checked back, sure enough, four billable hours went down the drain. Good thing he wasn't standing in the road.
BTW, engineer's solution: assume the infinite grid looks like a short to any one node except for the four resistors directly attached into the node. The parallel resistance into the node then is 1/4 ohm and therefore the resistance between any two, non-adjacent nodes is 1/2 ohm. With actual (cheap) 20% resistors thats close enough to the actual (.7xx is it?)
Dec28-07, 09:28 PM   #14
D H
Mentor
The resistance betweeb any two horizontally or vertically adjacent nodes is exactly 1/2 ohms. The resistance between nodes further apart than that is not. That 20% fudge on top of 0.5 ohms yields 0.6 ohms, not 0.773 ohms. Its even worse for nodes further apart than that.
Why don't you try working out the answer for nodes separated by two diagonal hops?
Dec28-07, 09:44 PM   #15
Recognitions:
Yes, ok, I'll have to make clear I'm using really cheap resistors when I go for the Google interview.
Think I'll code up a quick sim for fun.
Thread Closed
Thread Tools
Similar Threads for: Nerd sniping
Thread Forum Replies
Are you a nerd? General Discussion 196
The Nerd? Geek? or Dork? Test General Discussion 25
Does this make me a nerd? General Discussion 31
Nerd news site woos IT execs Computing & Technology 0
You know you are a nerd if... General Discussion 20
