Calculate Temperature at Bottom of 100m Waterfall: Help Needed!
  • Context: Undergrad
  • Thread starter Thread starter kurtlau
The temperature of water at the bottom of a 100m waterfall can be calculated using the principle of energy conservation. The gravitational potential energy (PE) at the top, given by the formula PE = mgh, transforms into kinetic energy (KE) as the water falls. This kinetic energy is then converted into thermal energy, leading to a temperature increase calculated using the equation ΔKE = mcΔt, where c is the specific heat capacity of water. Assuming all kinetic energy converts to thermal energy, the final temperature at the bottom is significantly higher than the initial 12℃.
  • Understanding of gravitational potential energy (PE = mgh)
  • Knowledge of kinetic energy (KE) and its transformation
  • Familiarity with the specific heat capacity of water
  • Basic algebra for solving equations involving energy
  • Calculate the specific heat capacity of water and its role in temperature change
  • Explore the conservation of energy principles in fluid dynamics
  • Investigate the effects of height on temperature in waterfalls
  • Learn about thermodynamics related to energy transformations
Students in physics, engineers involved in fluid dynamics, and anyone interested in thermodynamic principles related to energy conversion in natural systems.
kurtlau
A waterfall is 100m high and the temperature of the water at the top is 12℃.Assume that all the kinetic energy of the water reaching the bootom is changed into internal energy. Find the temperature of water at the bottom of the waterfall.
I don't know how to calculate~ Help me please and expaining particularly~ Thank you!
Science news on Phys.org
At the top, the water has gravitational PE = mgh (with respect to the bottom). That PE transforms into KE as it falls. Finally, the KE is transformed into thermal energy. ΔKE = mcΔt, where c is the specific heat of water (look it up!).
  • · Replies 32 ·
  • · Replies 109 ·
10K
9K
