Chemistry Question - Which Tests as an Acid Solution?
  • Thread starter Thread starter oceanflavored
    Chemistry
The discussion revolves around a chemistry homework question regarding which substances, when placed in water, will test as an acid solution. The focus is on understanding the behavior of specific compounds in aqueous solutions, particularly in the context of strong acids and hydrolysis reactions.
  • Homework-related
  • One participant asserts that HCl is a strong acid and will definitely test as an acid solution when dissolved in water.
  • Another participant questions the products of the reaction between CuSO4 and water, seeking clarification on whether any products are acidic.
  • A participant mentions that the book states CuSO4 gives off an acid solution when hydrolyzed in water, expressing confusion about how this conclusion is reached.
  • One participant suggests that the reaction between CuSO4 and water is a double displacement reaction, proposing potential products including CuO and H2SO4.
Participants generally agree that HCl will test as an acid solution. However, there is uncertainty regarding the behavior of CuSO4 in water, with differing interpretations of its hydrolysis and the resulting products.
The discussion highlights limitations in the provided information, particularly regarding the lack of explicit products for the reaction involving CuSO4 and water, which leads to differing interpretations of its acidic properties.
This discussion may be useful for students preparing for chemistry exams, particularly those studying acid-base reactions and hydrolysis processes.
oceanflavored
[SOLVED] chemistry question.
i'm studying for satII chem & got stuck on this problem. any help would be greatlyyy appreciated.
Which of the following when placed in water will test as an acid solution?
I. HCl (g) + H2O
II. Excess H3O+ + H2O
III. CuSO4 (s) + H2O
(A) I only
(B) II only
(C) I and II only
(D) II and III only
(E) I, II, and III
don't think you really need anyyyy.
but the book says the answer is (E).
well; I'm totally confused by this problem.
but i know (I) has to be true because HCl = strong acid. but as for the other ones, I'm very lost and would totally appreciate any help at alll.
thanks in advance! :)
[tex]H_3O^+[/tex] is also [tex]H^+[/tex]
III. what is the Product? Is either one of the products an acid?
[tex]CuSO_4 (s) + H_2O (l) \rightarrow ?[/tex]
thanks!
ok..thank you so much about the H3O
and as for the CuSO4 (s) + H2O
that's all the book says, there's no product.
their explanation is that the CuSO4 gives off an acid solution when it hydrolyzes in water.
but, i was confused as to how you would know that!
i hope that helps, rocophysics.
and thank you so much for your help!
Even though they don't give you Products, choice III is saying that Copper sulfate and Water react; though it does not explicitly tell you what those Products are.
Reaction III is a Double displacement rxn so
[tex]CuSO_4 (s) + H_2O (l) \rightarrow CuO (s) + H_2SO_4 (aq)[/tex]
rocophysics, you are amazing!
thank you SO much!
  • · Replies 16 ·
