| Thread Closed |
Absolute pressure at an ocean depth |
Share Thread | Thread Tools |
| Jan4-08, 08:06 PM | #1 |
a) Calculate the pressure at an ocean depth of 550 m. Assume that the density of sea water is 1022 kg/m3 and that the air above exerts a pressure of 101.3 kPa.
b) At this depth, what force must the frame around a circular submarine porthole having a diameter of 32.0 cm exert to counterbalance the force exerted by the water? I found the answer for (a) to be 5609880 Pa, but I am stuck on part (b). |
| Jan4-08, 08:23 PM | #2 |
Recognitions:
Assuming the inside of the sub is at atmospheric pressure all you need is the water pressure at that depth.
Since pressure is force / area. You have the pressure,you can get the area of the porthole so hat is the force? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Absolute pressure at an ocean depth
| Pressure in the Ocean | Introductory Physics Homework | 2 | ||
| Ocean Depth | Introductory Physics Homework | 2 | ||
| Water depth pressure against air pressure | Classical Physics | 1 | ||
| absolute pressure. depth | Introductory Physics Homework | 1 | ||
| ocean currents and fluid pressure | General Physics | 8 | ||
