Electric Field Strength of a Wire w/ Linear Charge Density
  • Thread starter Thread starter foxjwill
The discussion revolves around calculating the electric field strength produced by a wire with a uniform linear charge density, particularly in the scenario where the distance from the wire is much greater than its length. Participants are exploring the implications of this condition on the resulting electric field expression.
  • Participants discuss the integration of electric field contributions from different segments of the wire and question how to handle the limit as the wire length approaches zero in the context of the electric field expression. Some express confusion about the relationship between the parameters involved, particularly when considering the condition x >> l.
There are multiple interpretations of the problem, with some participants suggesting that the electric field can be simplified under the assumption that l is negligible compared to x. Others are questioning the validity of this assumption and exploring the implications of differentials in their reasoning. Guidance has been offered regarding the integration limits and the behavior of the electric field as parameters change.
Participants are navigating the complexities of the problem, including the definitions of "much greater than" and the implications of integrating over an infinite domain when considering a very long wire. There are also references to specific values and conditions from related problems that may influence the discussion.
foxjwill
Find the magnitude of the total electric field strength, [tex]E[/tex], at a distance [tex]x[/tex] produced by a wire of length [tex]l[/tex] and uniform linear charge density [tex]\lambda[/tex] such that [tex]x \gg l[/tex].
This how we went through it in class:
First, we realized that the electric field in the y direction would be zero. So, working in the x direction,
[tex]dE = \frac{kdQ}{\sqrt{x^2 + y^2}}\cos{\theta}[/tex]
Since [tex]\lambda[/tex] is a uniform, it will be the same no matter how small of a portion of the wire is taken, so we can say that [tex]\lambda dy = dQ[/tex]. Also, based on the graphic and some ingenious trig,
[tex]\cos{\theta} = \frac{x}{\sqrt{x^2+y^2}}[/tex].
So,
[tex]dE = \frac{xk\lambda dy}{(x^2+y^2)^{3/2}}[/tex].
Integrating from [tex]-l[/tex] to [tex]l[/tex],
[tex] E = {\int^l _{-l} \frac{xk\lambda}{(x^2+y^2)^{3/2}} dy}= \frac{2k\lamda l}{x\sqrt{x^2+l^2}}[/tex]
But the question has that [tex]x\gg l[/tex]. How does this work? According to our teacher (it's her first year teaching this particular course, and for some reason the previous teachers all decided, among other things, not to tell her what kind of questions to expect), the answer should come out to be
[tex]E = \frac{2k\lambda}{x^2}[/tex].
What's stumping us is how we can just get rid of [tex]l[/tex]. If it was just on the bottom, we could find the limit as [tex]l \rightarrow 0[/tex]. But as it is now, doing so would result in a value of 0, which is wrong.
I was thinking possibly of doing something with differentials,
(e.g.
[tex]dE = \frac{-2k\lamda (l dx (2x^2 + l^2) - x^3 dl)}{x^2(x^2+l^2)^{3/2}}[/tex]
[tex]\lim_{l \rightarrow 0} dE = \frac{2k \lambda dl}{x^2}[/tex]
but then what do we do with [tex]dl[/tex]?)
or maybe taking the limit as [tex](x-l) \rightarrow \inf[/tex] (which I'm not entirely sure how to do).
As far as I can tell, the correct answer is
[tex]E = \frac{2kl\lambda}{x^2}[/tex].
That makes sense because when [tex]x>>l[/tex] you are essentially looking at a finite lump of charge from a distance. Bigger [tex]l[/tex] means more charge so more E.
The correct answer is
From [tex]x\gg l[/tex] you have [tex]\frac{l}{x}\ll 1\Rightarrow \frac{l}{x}\rightarrow 0[/tex]. So write the denominator as
[tex]x\,\sqrt{x^2+l^2}=x\,\sqrt{x^2\left(1+(\frac{l}{x})^2\right)} \rightarrow x^2 \quad \text{for} \quad \frac{l}{x}\rightarrow 0 \quad \text{and} \quad x>0[/tex]
But if it's negligible compared to x, wouldn't changing it slightly not have much affect on E?
I was just thinking it through on the lines of differentials. Above, I wrote that
[tex]\lim_{l \rightarrow 0} dE = \frac{2k \lambda dl}{x^2}[/tex].
However, since [tex]x \gg l[/tex], wouldn't that mean that [tex]dx \gg dl[/tex]? So, that would mean that
[tex]\lim_{l \rightarrow 0} dE = \frac{2k \lambda}{x^2} {\lim_l \rightarrow 0} dl = 0[/tex]
and not [tex]\frac{2k \lambda dl}{x^2}[/tex].
Therefore, we can say that, overall, [tex]l[/tex] has negligible affect on [tex]E[/tex], and
Is this right?
HallsofIvy, the "k" is just the Coulomb's constant! Nothing peculiar :smile:
I found the actual question. It's similar to what I have above (which I'm still confused about; I don't really understand why you can keep the [tex]l[/tex] on top, but not on the bottom.), but not the same.
A very long, straight wire has charge per unit length 2.10e-10 C/m. At what distance from the wire is the electric field magnitude equal to 3.00 N/C?
The answer is 1.26 m, which can be gotten by plugging values into the formula:
[tex]E = \frac{2k\lambda}{x^2}[/tex],
where [tex]E[/tex] = electric field strength, [tex]k = \frac{1}{4 \pi \epsilon_0} \texttt{m/F}[/tex], [tex]\lambda[/tex] = linear charge density, and [tex]x[/tex] = distance.
Again, I got to
[tex]E = \frac{2kl\lambda}{x\sqrt{x^2+l^2}}[/tex].
Now, since this time [tex]l \gg x[/tex], what do I do?
Look at post #3
Hmm. I think what's tripping me up is the definition of "much greater than." Is there a rigorous definition?
I'm going to have to think of a better way to formulate my confusion.
Since now you have
you have to integrate in the domain [tex](-\infty,+\infty)[/tex] so the electric field is
[tex]E = \frac{2\,k\,\lambda}{x}[/tex]
Rainbow Child said:
Since now you have
Oh. That makes sense.
I'd still like to know if there's a rigorous definition for "much greater than."
As would I. Can anyone provide something? I am working with RF propagation, and far field region is defined as d>>wavelength. 10x? 20x? 100x?
  • · Replies 18 ·
  • · Replies 19 ·
