| Thread Closed |
Paleocene Sea level cycles? |
Share Thread | Thread Tools |
| Jan8-08, 07:22 AM | #1 |
We have discussed sea level yoyo's from the Pleistocene ice age of which it is suggested that it balances with the ice volume paced on the poles. So all of a sudden a study pops up (courtesy of the author), Dr Madeleine Briskin:
Briskin, M, Fluegeman R, 1990, Paleocene Sea Level Movements with a 430,000 Year Quasi-Periodic Cyclicity, Palaios V-5 p 184-198 |
| Jan8-08, 08:53 AM | #2 |
| Jan8-08, 12:22 PM | #3 |
As far as I can judge, an important part of the sea level cycle implies the changing ratio between coastal to deeper water single cell organism. The same technique I have seen being used here: see chapter 6 Eustatic sea level rise
Edit: futhermore it may be noted that we may have had an event, known as melt water pulse 1A, which also implied a quick sea level rise lacking evidence of a clear source. See this thread Furthermore the speculation of earth geometry changes related to eccentricity, again, is for the account of the authors. The only thing that matters is how accurate the sea level fluctuation has been identified/calculated. |
| Jan9-08, 11:00 PM | #4 |
Paleocene Sea level cycles?One may be able to use "continental rebound" or "tectonic rebound", for that matter, as a model for what you are trying to explain. The continental rebound or continental depression would not have to be caused by ice fields but could be cause by varying pressures, currents and densities of the mantle being influenced by the effects of the Milankovitch eccentricity cycle (over time). |
| Jan11-08, 04:19 AM | #5 |
Well let's say that to climatologists and astronomers we might as well live on a solid rigid rock that undergo all kind of orbits and cycles. Geographist and geologist would probably tend to focus on the whereabouts of the inside and outside of the Earth respectively, seeing a complex set of shells, dynamically reacting tor all kind of thermodynamic processes. Who would focus out to see a complex set of shells, dynamically reacting to all kind of thermodynamic processes, behaving as multiple interacting gyroscopes undergoing all kind of orbits and cycles?
| Jan11-08, 10:54 AM | #6 |
| Jan12-08, 11:10 AM | #7 |
(Glaciation?) Cycles all around this time 200.000 years
Isotopic Evidence for Glaciation During the Cretaceous Supergreenhouse |
| Jan29-08, 06:07 PM | #8 |
| Jan30-08, 08:18 AM | #9 |
That planetary interaction is one of the causes for the Milankovitch cycles, especially the eccentricity cycle, which appears pretty stable at around ~400,000 years, as it appeared visible as early as the Cambrian. In the least eccentric orbit there is little variation in climate but at the max eccentricity seasons may be more intens or a lot less, depending on the precession (~21ka) and obliquity cycle (~41). Anyway that's all way to slow for us to notice during a lifetime.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Paleocene Sea level cycles?
| Cycles in U-Joints | Mechanical Engineering | 0 | ||
| Paleocene Eocene Thermal Maximum: filling an ocean? | Earth | 23 | ||
| Cycles and Permutations | Introductory Physics Homework | 5 | ||
