| Thread Closed |
Fermion oscillator |
Share Thread | Thread Tools |
| May21-08, 12:37 AM | #69 |
Fermion oscillator[tex] \theta:=(1,0,0),\quad\eta:=(0,1,0) [/tex] in my previous post, because it seems extremely strange to use notation [tex] \int d\theta\;f(\theta) = \int d(1,0,0)\; f(1,0,0) [/tex] for anything. In fact now it would make tons of sense to define integrals like [tex] \int\limits_{\gamma} d\gamma\;f(\gamma) = \lim_{N\to\infty}\sum_{k=0}^N (\gamma(t_{k+1}) - \gamma(t_k))f(\gamma(t_k)) [/tex] where [tex]\gamma:[a,b]\to\mathbb{R}^3[/tex] is some path, and where we use the Grassmann multiplication [tex] \big(\gamma(t_{k+1}) - \gamma(t_k),\; f(\gamma(t_k))\big)\mapsto (\gamma(t_{k+1}) - \gamma(t_k))f(\gamma(t_k)). [/tex] For example with [tex] f(x_1,x_2,x_3) = (0,x_1^2,0) [/tex] and [tex] \gamma(t) = (t,0,0),\quad 0\leq t\leq L [/tex] the integral would be [tex] \int\limits_{\gamma} d\gamma\; f(\gamma) = (0,0,\frac{1}{3}L^3). [/tex] I'm sure this is one good definition for the Grassmann integration, but I cannot know if this is the kind that we are supposed to have. |
| May21-08, 12:46 AM | #70 |
| May21-08, 07:44 PM | #71 |
Recognitions:
integrals the first time I read it. Especially the generating functional Z(J) and what it is used for. Zee explains it more clearly and directly. After that, the more extensive treatment in P&S started to become more understandable. have time to fully deconstruct the details). If [itex]f(\theta)[/itex] is a constant, the integral is zero in standard Grassman calculus, but yours looks like it would give some other value. |
| May21-08, 11:52 PM | #72 |
My construction where
[tex] \theta=(1,0,0),\quad\eta=(0,1,0),\quad\theta\eta=(0,0,1) [/tex] was wrong. In P&S [tex]f[/tex] is said to be a function of a Grassmann variable [tex]\theta[/tex]. It is not possible for the theta to be a fixed basis vector. Okey, I still don't know what the Grassmann algebra is. If I denote [tex]G[/tex] the construction I gave in linear algebra subforum (basically [tex]G=\mathbb{R}^2[/tex] with some additional information), perhaps [tex] \bigoplus_{g\in G} \mathbb{C} [/tex] could be a correct kind of algebra... |
| May22-08, 07:04 PM | #73 |
Recognitions:
Then a 1-dimensional Grassman algebra consists of a single Grassman variable [itex]\theta[/itex], its complex multiples [itex]A\theta[/itex], and a 0 element, (so far it's a boring 1D vector space over [itex]\mathbb{C}[/itex]), and the multiplication rules [itex]\theta^2 = 0; A\theta = \theta A[/itex]. The most general function [itex]f(\theta)[/itex] of a single Grassman variable is [itex]A + B\theta[/itex] (because higher order terms like [itex]\theta^2[/itex] are all 0. A 2-dimensional Grassman algebra consists of a two Grassman variables [itex]\theta,\eta[/itex], their complex linear combinations, [itex]A\theta + B\eta[/itex], a 0 element, (so far it's a 2D vector space over [itex]\mathbb{C}[/itex]), with the same multiplication rules as above for [itex]\theta,\eta[/itex] separately, but also [itex]\theta\eta + \eta\theta = 0[/itex]. The most general function [itex]f(\theta,\eta)[/itex] of a two Grassman variables is [itex]A + B\theta + C\eta + D\theta\eta[/itex] (because any higher order terms are either 0 or reduce to a lower order term). And so on for higher-dimensional Grassman algebras. That's about all there is to it. Integral calculus over a Grassman algebra proceeds partly by analogy with ordinary integration. In particular, [itex]d\theta[/itex] is required to be the same as [itex]d(\theta+\alpha)[/itex] (where [itex]\alpha[/itex] is a constant Grassman number). This leads to the rules shown in P&S at the top of p300 -- eqs 9.63 and 9.64. |
| May23-08, 04:55 AM | #74 |
Also, if A and B are complex numbers, and I was given a quantity A+4B, I would not emphasize A and B being constants, and calling this expression the function of 4, like [tex]f(4)=A+4B[/tex]. |
| May23-08, 05:21 AM | #75 |
Or is it like this: [tex]\theta[/tex] can have different values, and there exists a Grassmann algebra for each fixed [tex]\theta[/tex]?
| May23-08, 07:25 PM | #76 |
Recognitions:
value of x you plug into f(x) _is_ constant. [itex]\theta[/itex] is an element of a 1-dimensional vector space. Besides [itex]\theta[/itex], this vector space contains 0 and any complex multiple of [itex]\theta[/itex], e.g: [itex]C\theta[/itex]. so this is not the same thing as [itex]A+B\theta[/tex]. |
| May24-08, 01:23 AM | #77 |
Here's my way to get Grassmann algebra, where Grassmann variables would be as similar to the real numbers as possible: First we define a multiplication on the [tex]\mathbb{R}^2[/tex] like it was done in my post in linear algebra subforum. That means, [tex]\mathbb{R}^2\times\mathbb{R}^2\to\mathbb{R}^2[/tex], For all [tex]x\in\mathbb{R}[/tex], [tex](x,0)(x,0)=(0,0)[/tex]. If [tex]0<x<x'[/tex], then [tex](x,0)(x',0)=(0,xx')[/tex] and [tex](x',0)(x,0)=(0,-xx')[/tex]. If [tex]x<0<x'[/tex] or [tex]x<x'<0[/tex] just put the signs naturally. Finally for all [tex](x,y),(x',y')\in\mathbb{R}^2[/tex] put [tex](x,y)(x',y')=(x,0)(x',0)[/tex] Now the [tex]\mathbb{R}[/tex] has been naturally (IMO naturally, perhaps somebody has something more natural...) extended to smallest possible set so that it has a nontrivial anti-commuting product. At this point one should notice that it is not a good idea to define scalar multiplication [tex]\mathbb{R}\times\mathbb{R}^2\to\mathbb{R}^2[/tex] like [tex](\lambda,(x,y))\mapsto (\lambda x,\lambda y)[/tex], because the axiom [tex](\lambda \theta)\eta=\theta(\lambda \eta)[/tex] would not be satisfied. However a set [tex] G=\bigoplus_{(x,y)\in\mathbb{R}^2}\mathbb{C} [/tex] becomes a well defined vector space, whose members are finite sums [tex] \lambda_1(x_1,y_1)+\cdots+\lambda_n(x_n,y_n). [/tex] It has a natural multiplication rule [tex]G\times G\to G[/tex], which can be defined recursively from [tex] (\lambda_1(x_1,y_1) + \lambda_2(x_2,y_2))(\lambda_3(x_3,y_3) + \lambda_4(x_4,y_4)) = \lambda_1\lambda_3 (x_1,y_1)(x_3,y_3) + \lambda_1\lambda_4 (x_1,y_1)(x_4,y_4) + \lambda_2\lambda_3 (x_2,y_2)(x_3,y_3) + \lambda_2\lambda_4 (x_2,y_2)(x_4,y_4), [/tex] where we use the previously defined multiplication on [tex]\mathbb{R}^2[/tex]. To my eye it seems that this [tex]G[/tex] is now a well defined algebra and has the desired properties: If one chooses a member [tex]\theta\in G[/tex], one gets a vector space [tex]\{C\theta\;|\;C\in\mathbb{C}\}\subset G[/tex], and if one chooses two members [tex]\theta,\eta\in G[/tex], then the identity [tex]\theta\eta = -\eta\theta[/tex] is always true. |
| May24-08, 02:31 AM | #78 |
Now I thought about this more, and my construction doesn't yet make sense. The identity [tex]\theta\eta=-\eta\theta[/tex] would be true only if there is a scalar multiplication [tex](-1)(x,y)=(-x,-y)[/tex], which wasn't there originally. It could be made it too complicated because I was still thinking about my earlier construction attempt...
I think this one dimensional Grassmann algebra can be considered as the set [tex]\mathbb{R}\times\{0,1\}[/tex] (with [tex](0,0)[/tex] and [tex](0,1)[/tex] identified as the common origin 0), with multiplication rules [tex] (x,0)(x',0)=(xx',0) [/tex] [tex] (x,0)(x',1)=(xx',1) [/tex] [tex] (x,1)(x',0)=(xx',1) [/tex] [tex] (x,1)(x',1)=0 [/tex] Here [tex]\mathbb{R}\times\{0\}[/tex] are like ordinary numbers, and [tex]\mathbb{R}\times\{1\}[/tex] are the Grassmann numbers. One could emphasize it with Greek letters [tex]\theta=(\theta,1)[/tex]. [tex] (x,0)(x',k) = (xx',k),\quad k\in\{0,1,2,3\} [/tex] [tex] (x,1)(x',1) = 0 [/tex] [tex] (x,1)(x',2) = (xx', 3) [/tex] [tex] (x,2)(x',1) = (-xx',3) [/tex] [tex] (x,2)(x',2) = 0 [/tex] [tex] (x,k)(x',3) = 0 = (x,3)(x',k),\quad k\in\{1,2,3\} [/tex] hmhmhmhmh? Argh! But now I forgot that these are not vector spaces... Why cannot I just read the definition from somewhere...btw. I think that if you try to define two dimensional Grassmann algebra like that, it inevitably becomes a three dimensional, because there are members like [tex] x\theta + y\eta + z\theta\eta [/tex] |
| May24-08, 05:34 AM | #79 |
strangerep, I'm not saying that there would be anything wrong with your explanation, but it must be missing something. When the Grassmann algebra is defined like this:
This is important. At the moment I couldn't tell for example if a phrase "Let [tex]\theta=4[/tex]..." would be absurd or not. Are they numbers that anti-commute like [tex]3\cdot4 = -4\cdot 3[/tex]? Is the multiplication some map [tex]\mathbb{R}\times\mathbb{R}\to \mathbb{R}[/tex], or [tex]\mathbb{R}\times\mathbb{R}\to X[/tex], or [tex]X\times X\to X[/tex], where X is something? |
| May24-08, 07:57 PM | #80 |
Recognitions:
skill to dislodge. There really is nothing more to it than that. This is all a bit like asking what [itex]i[/itex] is. For some students initially, the answer that "[itex]i[/itex] is an abstract mathematical entity such that [itex]i^2 = -1[/itex]" is unsatisfying, and they try to express [itex]i[/itex] in terms of something else they already understand, thus missing the essential point that [itex]i[/itex] was originally invented because that's not possible. |
| May25-08, 02:03 AM | #81 |
The biggest difference between [tex]i[/tex] and [tex]\theta[/tex] is that [tex]i[/tex] is just a constant, where as [tex]\theta[/tex] is a variable which can have different values.
If I substitute [tex]\theta=3[/tex] and on the other hand [tex]\theta=4[/tex], will the product of these two Grassmann numbers be zero, or will it anti-commute non-trivially: Like [tex]3\cdot 4= 0 = 4\cdot 3[/tex], or [tex]3\cdot 4 = - 4\cdot 3 \neq 0[/tex]? Did I already do something wrong when I substituted 3 and 4? If so, is there something else whose substitution would be more allowed? |
| May25-08, 03:28 AM | #82 |
Another one is where we identify all real numbers [tex]x\in\mathbb{R}[/tex] with diagonal matrices [tex] \left[\begin{array}{cc} x & 0 \\ 0 & x \\ \end{array}\right] [/tex] We can then set [tex] i = \left[\begin{array}{cc} 0 & 1 \\ -1 & 0 \\ \end{array}\right] [/tex] and we get the complex numbers again. [tex] \theta = \left[\begin{array}{cc} 0 & 1 \\ 0 & 0 \\ \end{array}\right] [/tex] and be happy. The biggest difference between this matrix, and the [tex]\theta[/tex] we want to have, is that this matrix is not a variable that could have different values, but [tex]\theta[/tex] is supposed to be a variable. .... btw would it be fine to set [tex] \theta = \left[\begin{array}{cc} 0 & \theta \\ 0 & 0 \\ \end{array}\right]? [/tex] |
| May25-08, 08:11 PM | #83 |
Recognitions:
change the notation a bit to be more explicit... Begin with a (fixed) nilpotent entity [tex]\Upsilon[/tex] whose only properties are that it commutes with the complex numbers, and [tex]\Upsilon^2 = 0[/tex]. Also, [tex]0\Upsilon = \Upsilon 0 = 0[/tex]. Then let [tex]\mathbb{A} := \mathbb{C}\cup \{\Upsilon\}[/tex] generate an algebra. I'll call the set of numbers [tex]\mathbb{U} := \{z \Upsilon : z \in \mathbb{C}\}[/tex] the nilpotent numbers. I can now consider a nilpotent variable [tex]\theta \in \mathbb{U}[/tex]. Similarly, I can consider a more general variable [tex]a \in \mathbb{A}[/tex]. I can also consider functions [tex]f(\theta) : \mathbb{U} \to \mathbb{A}[/tex]. More generally, I can consider two separate copies of [tex]\mathbb{U}[/tex], called [tex]\mathbb{U}_1, \mathbb{U}_2[/tex], say. I can then impose the condition that elements of each copy anticommute with each other. I.e., if [tex]\theta \in \mathbb{U}_1, ~\eta \in \mathbb{U}_2[/tex], then [tex]\theta\eta + \eta\theta = 0[/tex]. In this way, one builds up multidimensional Grassman algebras. |
| May26-08, 05:30 PM | #84 |
Okey, thanks for patience
I see this started getting frustrating, but I pressed on because confusion was genuine.So my construction in the post #67 was otherwise correct, expect that it was a mistake to define [tex] \theta:=(1,0,0),\quad \eta:=(0,1,0). [/tex] Instead the notation [tex]\theta[/tex] should have been preserved for all members of [tex]\langle(1,0,0)\rangle[/tex] (the vector space spanned by the unit vector (1,0,0)), and similarly with [tex]\eta[/tex]. |
| Jun27-08, 04:41 AM | #85 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Fermion oscillator
| The Fermion Cube | Beyond the Standard Model | 19 | ||
| four fermion interaction?? | Quantum Physics | 1 | ||
| Bulk Fermion in RS1: What sets fermion parity? | General Physics | 1 | ||
| Fermion | High Energy, Nuclear, Particle Physics | 4 | ||
| Fermion+Fermion = Boson ? | Quantum Physics | 11 | ||
