Aerodynamics of a racecar undertray
  • Thread starter Thread starter Renegade
    Aerodynamics
The recent changes to the undertray design of IRL racecars aim to enhance safety by preventing lift during skidding. The new undertray features a curved design that raises the outer edges by 10 mm, effectively increasing ride height and reducing downforce while improving yaw stability. This design modification channels airflow more effectively, preventing air buildup that could lead to lift, contrary to concerns about airflow creating unwanted lift due to the undertray's shape. The aerodynamic principles at play are crucial for maintaining vehicle stability in high-speed racing conditions.
  • Understanding of basic aerodynamics principles, particularly lift and downforce.
  • Familiarity with the design and function of racecar undertrays.
  • Knowledge of airflow dynamics and how they apply to vehicle motion.
  • Awareness of the impact of vehicle design changes on racing performance.
  • Research the effects of undertray design on vehicle aerodynamics in motorsports.
  • Study the Bernoulli principle and its application to racing vehicle dynamics.
  • Explore advanced aerodynamic modeling techniques for racecar design.
  • Investigate the relationship between ride height adjustments and vehicle stability in racing scenarios.
Race engineers, automotive designers, and motorsport enthusiasts interested in the aerodynamic performance and safety enhancements of racecars.
Renegade
This is a question about aerodynamics & lift/downforce created by a change in the undertray design of an IRL car..
The IRL racing series announced yesterday a number of changes to car design in order to keep cars from lifting off the ground, as they were for some unknown reason especially prone to do last year. One of the new changes is to the undertray of the car which was essentially 'flat' last year:
The plate(undertray) will now curve from its center up toward the wheels on each side, so that the outside edges are 10 mm higher than the center. The curved skid plate effectively raises ride height 10 mm, and serves two purposes, according to Barnhart: It reduces downforce and improves yaw stability. It does that by channeling air out the other side of the bottom of the car if it skids, rather than allowing the air to build up and thus create lift
Not sure that means too much to anyone, but basically the bottom of the car will be a *very-flat "V"* as you look at it from nose to tail.
Now imagine a car skidding sideways.
The diagram below is extremely crude & exaggerated(it is a curve in real life):
\______ _______/
_______V__________ <--flat ground
==> direction of air underneath car
My (non-physics-background)-thinking is that air encountered by the forward side of the undertray will get squeezed or "scooped" underneath and as it gets trapped towards the centreline the lowest(narrowest) point.
I would think this would create LIFT, the exact opposite of the desired affect.
Someone I was discussing this with mentioned aircraft wings & the Bernoulli prinicple, but an open-wheel racecar is not 'wing' shape when looking at it from the side!
Can someone explain how the airflow under a sideways-sliding car with a 'V' bottom would act?
If the air is 'squeezed' so that more air is forced through a given space its velocity would increase. An increase in velocity would result in a drop in pressure.
Cliff
  • · Replies 20 ·
  • · Replies 19 ·
9K
