Solve Elevator Problem: Find Motor HP of 1000 kg Lift
  • Thread starter Thread starter KingNothing
    Elevator
The discussion centers on calculating the horsepower required for a 1000 kg elevator with a maximum load of 800 kg, facing a frictional force of 4000 N, to lift at a speed of 2 m/s. The correct formula derived is P = v(mg - f), leading to a calculated power output of 36.6 hp. The initial confusion regarding the relationship between speed and distance was clarified by expressing time in terms of distance and speed. The final answer of 5.92 hp was corrected to 36.6 hp based on the proper application of energy equations.
  • Understanding of basic physics concepts such as work, energy, and power.
  • Familiarity with the equations of motion and forces acting on objects.
  • Knowledge of horsepower and its conversion to watts.
  • Ability to manipulate algebraic equations to solve for unknowns.
  • Study the principles of work and energy in physics.
  • Learn about the calculation of power in mechanical systems.
  • Explore the effects of friction on moving objects and how to quantify it.
  • Investigate real-world applications of horsepower in elevators and other lifting mechanisms.
Engineers, physics students, and professionals involved in mechanical design, particularly those working with elevator systems and load calculations.
KingNothing
Hey all..here is another stumper (for me).
"A 1000 kg elevator has a maximum load of 800 kg. If constant friction retards the elevator at 4000 N, to lift at 2 m/s, what does the motor's hp(horsepower) have to be?"
Now, I was trying to do a lot of things with this one. I thought it was an obstacle that we had a speed and not a distance. I tried getting around this by simply acknowledging that since we went to go 2 m/s, and since a watt is 1 J/s, that I could just sort of throw the /s off each of them and leave it at 2 m. Prolly totally off.
Any Help?
(My answer was 5.92 hp)
Use energies. From point A to a higher point B, the equation looks like this:
[tex]W_{motor} + W_{friction} = \Delta E_m = \Delta E_p + \Delta E_k[/tex]
[tex]Pt - f\Delta h = mg\Delta h + (0)[/tex]
Where P is the power of the motor, t is the time the eleavtor takes to travel the distance from A to B, f is the force of friction and Δh is the distance from A to B. We need to get rid of the time there, so we express it as t = Δh/v, where v is the elevator's constant speed:
[tex]P\frac{\Delta h}{v} + f\Delta h = mg\Delta h[/tex]
Now rearrange the equation, cancel Δh and you get:
[tex]P = v(mg - f)[/tex]
And voila. :smile: I get P = 36.6hp.
I love you Chen.
11K
