How Can You Weigh a Ship Without a Scale Using Fluid Dynamics?
The discussion revolves around the problem of determining the weight of a ship using fluid dynamics principles without the aid of a scale. Participants explore various methods and calculations related to buoyancy, water displacement, and measurement techniques, with a focus on theoretical and practical implications.
  • One participant suggests measuring the water level before and after the ship is lowered to calculate the weight based on the volume of displaced water.
  • Another participant raises concerns about measuring surface area if the pool is not a standard shape, questioning the feasibility of the initial method.
  • A participant provides a rough estimation of weight variance based on ship length and measurement accuracy, discussing the implications of these estimates.
  • Some participants mention the laws of buoyancy, explaining that the weight of the displaced water equals the weight of the ship, while others challenge the relevance of certain contributions to the problem.
  • There are discussions about the accuracy of measurement tools and the assumptions made regarding water density and pool shape.
  • A later post introduces a different scenario involving measuring the volume of water in a land-locked lake, proposing methods that involve chemical tracing and sampling.
Participants express differing views on the methods for calculating the ship's weight, with no clear consensus reached. Some methods are supported while others are challenged, indicating ongoing debate and uncertainty regarding the best approach.
Limitations include assumptions about the shape of the pool, the accuracy of measurement tools, and the density of water, which may vary based on conditions not specified in the discussion.
shamrock5585
so your company has built an enormous ship and it is being lowered into a large pool to test if it can float... another company has contacted you to buy your ship and they want to know how much the ship weighs... your company has spent all its money building the ship and you can't afford a scale... if you cannot give the company an accurate weight for the ship they will not buy it and your company will go bankrupt... the only tools you have are a meter that measures the volume of the water in tank, a gun and a basic knowledge of fluids... can you find the weight of the ship and save your company or should you use the gun to off yourself?
You just need know the water level before and after the ship is lowered into the pool.
Then multiply this difference (in meters) by the pool's surface (in m2) to get the weight in tons.
Yeah, I got to say, Rogerio's method is bound to be simpler. The only thing you need to do is take linear measurements.
But Rog: what if the pool is amorphous in shape? How would you measure the surface area then?
shamrock: I don't know what kind of meter will "measure the volume of water in the pool" directly.
Well Dave, I know my own weight.
So, I would jump into the pool...
:smile:
Heh, assuming you have accurate tools, or the pool has a small surface area! Would be interesting to see about what level of accuracy you could get in that circumstance! Maybe the "volume-meter" is super accurate!
DaveE
So, at a rough estimation:
- Average ratio of length to width of some large ships: 6.7:1
- Assume pool is rectangular and has 10 feet of extra room around the edges (in reality I don't think they'd use such pools, but if they did they'd probably have more leeway-- but trying for best case)
- Assume water's density is about 62.3 lbs per cubic foot (it's probably not pure water, and is likely at some temperature between 4C and 20C-- fortunately it doesn't change much)
- Assuming you can get a 1/2 inch accuracy on your vertical measurement (no clue how realistic that is)
Ship Length - Expected % error
100 ft => +/- 5.4 tons
200 ft => +/- 14.2 tons
300 ft => +/- 26.9 tons
400 ft => +/- 43.4 tons
500 ft => +/- 63.8 tons
600 ft => +/- 88.1 tons
700 ft => +/- 116.2 tons
800 ft => +/- 148.3 tons
900 ft => +/- 184.1 tons
1000 ft => +/- 223.9 tons
1100 ft => +/- 267.5 tons
1200 ft => +/- 315.0 tons
1300 ft => +/- 366.4 tons
1400 ft => +/- 421.6 tons
1500 ft => +/- 480.8 tons
I figured that would be too much of a variance (admittedly I haven't checked much), but in comparing a couple actual ship tonnages, it's within 0.2% or so. So that's probably reasonably accurate!
DaveE
I'm curious about the gun.
Well, using the smallest pool in the above, we can know the gun's mass to within 5.4 tons. Will that work?
DaveE
answer: well basically the gun had nothing to do with the problem... you can find the weight with laws of buoyancy... a floating object (which has a specific gravity of less than 1) experiences an upward force equal to the weight of the water that it displaces... so you figure out the volume of the water in the tank before the ship is lowered into the pool and then the volume after the ship is floating in the pool... the volume of water which is displaced is the difference in the two values... then with your basic knowledge of how much that volume of water would weigh (roughly 8 pounds per gallon) you can find the weight of the water that was displaced which is equal to the upward force acting on the ship which is equal to the eight of the ship itself!
Well. it seems the shamrock's reasoning is not related to this problem, since any ship has specific gravity greater than 1...
:smile:
Anyway, the correct solution had already been stated (see the second post).
Just a little thought to consider.
Hulls are painted, water lines established, and depth markings are calculated before the boat or ship ever hit the water. -:)
shamrock5585 said:
... a meter that measures the volume of the water in tank, ...
That part should be re-worded because the volume of the _WATER_ is staying the same, it's obvious what you mean but you should say it.
OK, I got another water-measurement one.
You've been tasked with measuring the amount of water in a land-locked lake (no inlets or outlets, i.e its volume does not change over time). It has a highly irregular shape and a highly irregular bottom, the depth of which you don't know. How can you measure the amouint of water?
Hmm. My first thought was that there might be a solution involving the tides of the lake, but I'm not sure if that would actually work or not. Another thought I had was to put a measurable amount of some sort of traceable chemical.
Now, stir the lake up :) Use boats, little kids, fish, big spoons-- whatever's handy. Take random samples and test the concentration of the chemical. When your sample sizes start to be more and more consistent (at varying depths, locations, etc), you can stop stirring. At that point, you should be able to get a pretty good guess at how much water there was to start with.
DaveE
As the problem is originally stated, read the volume meter in cubic meters. I have no idea how this meter works but I don't care. Lower the boat. The water will rise as the boat is lowered, volume staying the same. Drain the water until the height is back to what it was. Now read off the new volume. Absolute Delta Volume is the mass in metric tons.
11K
  • · Replies 21 ·
9K
  • · Replies 19 ·
