Cracking the Physics Olympiad Problem: Expressing V in 5 Parameters
The discussion centers on solving a complex physics problem involving a magnet falling through a glass tube with steel rings. The key parameters affecting the final speed V of the magnet include the distance H between the rings, the radius R of the rings, the conductivity ρ, the mass m of the magnet, and its magnetic moment μ. The consensus is that when each of these parameters is doubled, the final speed V also doubles. The solution involves applying the Lorentz force and the Biot-Savart law to derive the relationship between these parameters and the final speed.
  • Understanding of electromagnetism principles, specifically the Lorentz force and Biot-Savart law.
  • Familiarity with the concepts of magnetic moment and induced electromotive force (EMF).
  • Knowledge of basic kinematics and equations of motion.
  • Ability to manipulate and analyze equations involving multiple variables.
  • Study the Biot-Savart law in detail to understand its application in calculating magnetic fields.
  • Learn about Faraday's law of electromagnetic induction to relate magnetic flux changes to induced EMF.
  • Explore the principles of motion under the influence of magnetic forces to deepen understanding of the problem.
  • Practice similar physics Olympiad problems to enhance problem-solving skills in electromagnetism.
Students preparing for physics Olympiads, educators teaching electromagnetism, and anyone interested in advanced physics problem-solving techniques.
olympiad
hey, I have a tough time cracking this one
The other problem is:
Imagine a glass tube with steel rings around it which have a conductancy rho and a half diameter of R. they are spaced with a distance H.
inside the glass tube is a much smaller glass tube. Through it you drop a magnet with mass m and magnetic moment mu. the magnet will reach a final speed V quite soon. Explain with which factor the endspeed V will change if in five different experiments the five parameters(H,R,rho,M,mu) are doubled. You can neglect all form of friction, selfinduction and reciprocal induction.
I have a partial answer. You have to express v in the five parameters and then it is easy. If the speed is constant all height energy over a height H will be transferred into electric energy, so MHg=Pt with P the electric power and t the time that it takes to fall down a length of H. that time t is V/H. P is I^2*R.
So MHg=(V/H)*R*I^2. the problem is, how do you express I? mu=a*m^2 so I thought that the solution would be I=mu/(pi*R^2). (magnetic moment divided by area of one ring) But that can't be true because other rings have influence too, and now I just calculate the influence of one ring. Also, I don't take into account the distance between the rings. If you express V in this way H isn't in the formula, that can't be right. Help me please? thank you in advance.
olympiad
level questions are hard. The way to solve this problem is to use the equation of motion. Since there is no friction or self-induction, the only force acting on the magnet is the Lorentz force due to its interaction with the rings. The equation of motion is F = ma, so the acceleration of the magnet is given by F/m. We then need to calculate the Lorentz force. This can be done using the Biot-Savart law, which states that the magnetic field B at a point P due to a current element I is given by B = (mu_0I)/(4*pi*r^2) where r is the distance from the current element to P. We can integrate this over all the current elements in the rings to get the total Lorentz force. Now that we have the equation of motion, we can find the final speed V. We can then use this to calculate how V changes when the five parameters are doubled. The answer should be that V is doubled in each experiment.
Hi there,
I understand that you are struggling with this physics olympiad problem and have been working on finding a solution. It seems like you have made some progress in expressing V in terms of the five parameters, but you are still unsure about the accuracy of your solution. I would suggest taking a step back and reviewing the problem again to make sure you fully understand what is being asked.
One approach you can take is to break down the problem into smaller parts and tackle them one at a time. For example, you can start by considering the effect of doubling each parameter individually and see how it affects the final speed V. This can give you some insight into how each parameter contributes to the overall result.
Additionally, you can try using some basic principles and equations from electromagnetism to help you in your solution. For example, you can use Faraday's law to relate the change in magnetic flux to the induced electromotive force (EMF) in the loop of wire. This can help you express V in terms of the magnetic moment mu and the area of the loop.
It's also important to keep in mind the assumptions made in the problem, such as neglecting friction and self/induction. Make sure you are not including them in your solution as they may lead to incorrect results.
I hope this helps and good luck with your solution! Remember to take your time and approach the problem systematically. With some persistence and critical thinking, I am sure you will be able to crack it. Best of luck!
9K
