| Thread Closed |
Thermocouple-Uses and how it Works??? |
Share Thread | Thread Tools |
| Jan11-08, 03:44 PM | #1 |
I need to investigate how current in a diode varies with extreme temperatures. I have no idea how to do this but could a thermocouple somehow be incorporated into the investigation. 2. Relevant equations Can a thermocouple be used to investigate this 3. The attempt at a solution I have no idea how a thermocouple works or what it exactly does, so i have no attempted solutions. |
| Jan11-08, 03:48 PM | #2 |
Recognitions:
Not sure what you mean by looking at the current in the diode.
An intersting (and useful) property of diodes is that the forward voltage drop depends on temperature - this is used as a temperature sensor. It doesn't really matter what you use as a sensor to make your measurements, thermocouples have the advantage that they are fairly small and so can be easily attached to a diode. You will need a thermocouple reader - some digital voltmeters have them built in. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Thermocouple-Uses and how it Works???
| Differential Thermocouple Amp | Engineering, Comp Sci, & Technology Homework | 5 | ||
| I was wondering why this works and if it works every time | Calculus & Beyond Homework | 3 | ||
| Thermocouple | Introductory Physics Homework | 1 | ||
| thermocouple | Electrical Engineering | 8 | ||
| thermocouple and surface | General Physics | 1 | ||
